4x4 Is It Needed
#34
4x4
I used non 4x4 for years and got real lucky. I was the master on getting 18,000 lbs out without a 4x4. Only once did we have to strap onto someone else's to duoble pull out. I did not have a dually. A dually will spin very easy.
Now with a 4x4 in low, it feels like someone rear-ended me as I fly up a ramp. You have all winter to look. Go to auto trader.
Mark
Mark
#35
'05 Concept SF23
I tow a 43 Black Thunder with a 1997 Chevy 2wd crew cab dually. Boat on the trailer weighs about 14,500 lbs. Never had a problem on a ramp. I am particular about the ramps I use. Get a locking rear. Drive it up the ramp in low like you had a egg under the gas pedal. As for backing down get a trailer with electric over hydraulic disc brakes. Back down in neutral so the rear wheels are not driving and let gravity do the work. Make sure the truck has 4 wheel disc not rear drum brakes, as this will also help. 4wd costs about 1 mpg going down the road and costs to maintain. It is a bad idea to back down in drive, check the owners manual.
#36
Thinking Of Something Like This Instead Of The 4x2 Dully After I Read All Of Yall's Post. I Wanted To Slamm The Dully On The 24.5 But As Most Of Ya Guys Probably Know Ya Can Slamm 4x4 So Now I Will Lift On Some 44 Or 46 Inch Swampers
Donz Jr Mike
Donz Jr Mike
#38
Dont go too big or towing will be a problem. ya gotta keep your truck usable.
I've got 6" of lift and 35's. Im gonna squeese 37 on this spring.
#40
With 13k you need to keep it stock and strong when it comes to suspension...24.5's or boggers won't have the load rating needed to tow the Cig.
4x4 is a cheap form of insurance and the one time you need it will pay for itself
