Stupid Engineering
Old 11-05-2004 | 04:54 PM
CAP071's Avatar
Default Re: Stupid Engineering
Yes my GTO 400 had that also.
Why do they have the oil filter upside down?
CAP071 is offline
Old 11-05-2004 | 05:57 PM
Reed Jensen's Avatar
So it will make a mess when you unspin it... also .. so that you cannot fill it before you put it on... that way all the air inside has to pass through the bearings before any oil gets there.... in other words.. Because some moron designed it that way.
Reed Jensen is offline
Old 11-05-2004 | 06:01 PM
CAP071's Avatar
Hmmmm damn Mercruiser people
CAP071 is offline
Old 11-05-2004 | 08:07 PM
robyw1's Avatar
The TRI-HULL runabout
Roby
robyw1 is offline
Old 11-05-2004 | 08:33 PM
Formula Outlaw's Avatar
Manatee Zones, I know it's not "engineered" but it is "engineered against us".
Formula Outlaw is offline
Old 11-05-2004 | 08:48 PM
38KV's Avatar
Center rise exhaust manifolds.
It's almost impossible to pull the valve covers without pulling the manifolds.
I recently adjusted the valves on my buddy's triple engine boat with GIL's.
38KV is offline
Old 11-05-2004 | 09:21 PM
GLH's Avatar
GLH
Punch the top of your filters so it will drain before taking them off. Now if they're sideways like mine your screwed every wich way!
GLH is offline
Old 11-05-2004 | 10:27 PM
Infomaniac's Avatar
How about this one?
It's all just a matter of weight and balance.
I avoid calling this a redneck roller coaster. As there are a fair share of rednecks around here.
None dumb enough to ride this one.
Yee Ha Baby
Infomaniac is offline
Old 11-05-2004 | 11:01 PM
2112's Avatar
Originally Posted by Reed Jensen
It wasn't wood... it was phenolic resin with cloth laminated in it... but it can look like wood. Pontiac 400's had them... they were notorious for failing. Ford used them in the gear drive camshafts on the V-12's... they were a little more successful there.
Which V-12 are you referring too?
2112 is offline
Old 11-06-2004 | 04:08 AM
This kind of V-12.... or didn't you know Ford built a V-12?... They were in the Late 30's to late 40's Lincolns and Zephyrs.........
