Stupid Engineering
Old 11-07-2004 | 11:37 AM
Ed
Default Re: Stupid Engineering
The up-side-down oil filter on the Mercruiser engines was designed to bring the oil filter closer to the top/front area of the engine for easier access with oil & filter changes. Every one of these filters that I have ever removed was pretty much empty when it came off, because it is up-side down vertically. The minor amount of oil droplets lost sure outweighs the bilge crawling in years past. My .02. Ed
Ed is offline
Old 11-07-2004 | 12:06 PM
Two more
Un-necessary thru hull fittings below the waterline.
Hour meters wired to run with accesories on vs. actual engine running time.
ed
Interceptor is offline
Old 11-07-2004 | 12:22 PM
Reed Jensen's Avatar
Originally Posted by Too Old
Electric activated hatch lifts with batteries mounted in the bilge and no provision for the dead battery scenario....
I dealt with that problem by adding "jumper wires" under the rear seat. That way I could always energize the circuit that had the engine hatch connected to it......
Reed Jensen is offline
Old 11-07-2004 | 04:43 PM
Lee's Avatar
Lee
Ford still builds a V-12
Lee is offline
Old 11-07-2004 | 05:37 PM
Waterfoul's Avatar
Gone Fishin'
Originally Posted by GLH
Punch the top of your filters so it will drain before taking them off. Now if they're sideways like mine your screwed every wich way!
Do yourselves a favor and mount the enitre oil filter assembly on the port side transom and be done with it! Never makes a mess when changing. Or, if you have twin engines and can't get back there, mount them on the bulkhead of the back seat. I've seen it done both ways.
'Foul
Waterfoul is offline
Old 11-07-2004 | 07:27 PM
Sydwayz's Avatar
Forum Regulator
Auto Bilge Pump Float Switches that do not float. Check this thread out:
http://www.offshoreonly.com/forums/s...t=bilge+switch
Sydwayz is offline
Bryan Rose
8
03-01-2008 11:00 AM
Dblvanos
11-27-2007 05:04 PM
382 newbie
0
06-07-2007 08:13 AM
CigDaze
07-17-2002 10:29 AM
