is a dually needed to tow and dip 35ft 10k lb
Dually's don't raise the tow capacity just make the truck a little more stable when towing.. Imo If you use the truck for towing heavy loads on a daily basis go with a dually but if you just use it on weekends or less go with a srw their easier to get around in tight places.
Bingo. I agree with this.
Make sure you check the hitch on ANY truck. Most tow packages have a class IV hitch. One should really consider moving up to a Titan Class V hitch for added capacity.
Just FYI.
Just FYI.
IMHO, the dually will make it more stable, but I wouldn't sweat pulling it with a SRW truck as long as the brakes are setup and working on the trailer you're pulling and your hitch is rated for the load you're hooked up to.
Ditto
Ditto
All 3/4 ton trucks do not have the same towing capacity. You need to make sure that the truck you buy is rated for the capacity you need. Also a class V hitch platform is a necessity. Be careful because if you have an accident while towing, both your auto and boat insurance companies will verify that the truck was rated for the load you were hauling.
As far as brakes between a srw chevy 3/4 hd they are identical to the dually,as is the frame,ring and pinion size,sway bars etc,Smitty
Rat,,
If your interested, my Daughter starts College next year so I am going to part with my "BABY" if your still in the Market! I won't bore you with details, but itsa Garage Kept 1999 F350 Lariat, XLT, Leather & Loaded, 140,xxx miles, 18 g's for it, like I sd this is my Dream Truck and I have treated it that way. I had the Decals removed yesterday so its solid white now. I'll post a new Pic Tonight. I'll have Graphics made to match your Boat at no extra Charge too. with in reason
Mitch
Mitch
