how well does a gm 6.2l non/turbo deisel pull? >
Old 12-21-2004 | 09:05 PM
t500hps's Avatar
21 and 42 footers
Default Re: how well does a gm 6.2l non/turbo deisel pull?
A freind on mine had a (90ish) suburban with that motor in it. I don't think it could pull his lawnmower trailer at 75mph! Ask for a test drive???
t500hps is offline
Old 12-22-2004 | 07:13 AM
jdnca1's Avatar
My dad still has an old suburban around the farm with a 6.2L diesel in it 4.10 gears. The thing is a complete DOG...a small block chevy truck will run circles around it. The 6.5L motor is much better.
jdnca1 is offline
Old 12-22-2004 | 07:33 AM
PatriYacht's Avatar
That truck pulling a 12,000 lb load. You'd be lucky to get 65 with your foot on the floor. I'd run away from that one.
PatriYacht is offline
Old 12-22-2004 | 08:01 AM
I have one. 85 6.2 2500 GMC with a th400. You would not be happy with that truck. They run for ever but do not have anywhere near the performance of the new ones. They are low in HP (140) so they are geared high. 65 is the max speed I take mine cause she is turning some RPM. Your boat weighs too much. You might hit 45 up hill. Find a turbo if you want to travel at those speeds.
squirt is offline
Old 12-22-2004 | 08:17 AM
robyw1's Avatar
The 6.2s are doing good to pull the truck much less a trailer.
robyw1 is offline
Old 12-22-2004 | 08:28 AM
Perfectmix's Avatar
Make sure you have lots of cleaner on hand so you can wipe the boat clean of all the soot that 6.2 will spew out. Good luck!
Perfectmix is offline
Old 12-22-2004 | 08:38 AM
ernie davis's Avatar
Used to call them mash-motors........just mash the gas peddle and wait for it to creep up to the speed limit
Had friends with them back in the day, ran forever.
Can play with the injector pump pressure, up for a little performance, down for better mileage (and absolutely no acceleration).
ernie davis is offline
Old 12-22-2004 | 09:16 AM
mcollinstn's Avatar
Yeah.
* not a converted gas motor
* very durable and dependable
* slow as a slug
* zero resale value (which means you should be able to buy one cheap).
mcollinstn is offline
Old 12-22-2004 | 10:03 AM
No way. had one in a suburban, and it would barely pull itself.....
Madmax is offline
Old 12-22-2004 | 04:26 PM
articfriends's Avatar
I did a 700r4 trans 5 years ago for some guys from canada in a chevy wrangler 1/2 ton(i guess thats what they call a silverado),it had 3.42 gears and SCREAMED like a built smallblock,no turbo either but ALOT of motor work but it was the ONLY one ive ever driven that could get out of its own way,Smitty
articfriends is offline
