-   -   Engine protectant (https://www.offshoreonly.com/forums/general-boating-discussion/93439-engine-protectant.html)
Stormrider 12-30-2004 12:37 PM
Engine protectant
I was told to spray CRC on my engine and all other components in the engine compartment. Or WD40 would do. I didn't like using the WD40 and I see CRC makes many different marine products.
Do you spray anthing to inhibit corrosion, and if so, what do you use?
Sean 12-30-2004 12:43 PM
Re: Engine protectant
storm...i think its the 656...
Stormrider 12-30-2004 12:58 PM
Sean, you use it?
How about the Heavy duty silicone spray?
CAP071 12-30-2004 01:20 PM
I was told that before also to just spray down the motor
prevents moisture and corrosion
Sean 12-30-2004 01:43 PM
i use it on everything... cars, boats...
i do not use silicone...it tends to leave a residue.
Stormrider 12-30-2004 02:02 PM
ok, thanks... where to buy?
open87 12-30-2004 05:51 PM
http://www.seadoo.com/en-US/Watercra...productCode=37
this works real good .
Biggus 12-30-2004 06:24 PM
I'm a WD40 guy. Why don't you like WD40? Tomorrow I'm going to celebrate 50 years of WD40 :evilb: :drink: :D
frequentflyer 12-30-2004 07:21 PM
WD40 baby all the way...
Titan 12-30-2004 07:33 PM
WD 40 is definatly good to use. But for the long cold winter try T9 Bowshield. It is not cheap at 7 or 8 bucks a can but it will stay on the engine all winter. It does leave a film but is easy to wipe off and the engine stays brand new. This product was designed for the aircraft industry.
