Re: OK, I bought my first offshore performance boat; now what?
Originally Posted by Crazyhorse
In a nutshell, get the largest home equity loan you can get and send in all those credit card applications. Summer is coming and you'll need the extra credit for all the gas you're going to use.
Oh, and buy the biggest, baddest pickup truck that you can find to pull it with. The boat will be on a lift most of the time at our dock, but I would love to have a 2500 Duramax! |
Ummm... just one thing.
I started with cruisers and worked back to performance. A skinny boat with twin I/Os simply can't do some of the tricks that fat twin IBs can do. The props are way farther back, closer together and you have no separate rudders. (required for the "sideways" move. sorry) The experience you had with the last boat will help you in the long run, and you will get the hang of what you can and can't do with twin I/Os. But you will be disappointed if you expect to pull sideways off of a pier or turn 360 in one place. Your new boat will turn on an axis that is forward of what an IB cruiser can do. I'm guessing that you have counter-rotating drives on the new boat. You will find that one will "walk" one way, and the other will "walk" the other way in reverse. My bet is that you end up using one more to pull alongside with your SB, and the other to pull alongside with your port. Now.... go buy some gold chains and some cool sunglasses. You are a performance boater. You will also need the theme from Miami Vice on MP3 so it doesn't skip. :D |
CoBerry, welcome to the club. We also came from 20-23 footers into a longtime dream.
Chart and RonP are dead on. Know your neutral positions for drives/tabs and make it second nature hitting those buttons correctly. We are running a stepped/notched hull and have taken our progression into speed very slow. Still a ton to learn like yourself and we will be loving every minute of it. Now post some pic's, it was 18 degrees here this morning and I need a boat fix. |
put up some pics CObarry.... it is always nice to see another performance boat on LOTO, i was getting worried that everybody was buying 50+ sea rays.... :rolleyes: :D
Originally Posted by CObarry
Thanks, Chart; just the type of advice I was looking for. I'd love to meet up with you sometime and buy you a beer or 6! :drink:
The 336 is not a stepped hull, but it does have a notched transom, if that makes any difference.
Non-stepped hulls are easy and forgiving to drive. Only thing to remember is not to enter into a high speed turn with the drives trimmed out much. You most likely won't get hurt, but the props will probably loose their bite and that's hard on equipment. Set the drives neutral or trim in and you'll carve through the turn hard enough to understand why the bolster is so tight! :D Stepped hulls handle differently, and using the same technique can throw you into the water. That brings up another good point: The kill switch lanyard: Wear it.
Also, I think I know the answer, but what is porpoising? Is that bouncing the bow up and down?
3 Attachment(s)
Here are some pics.... |
Originally Posted by Ron P
This is KEY. Get everything level with the bottom of the boat and then use a dot of nail polish and mark the indicators panel so you know where everything is level. Also make sure the buttons are wired correctly. When you push the top of the button (toward bow) the tabs should drop and the drives should come in. Pushing the back side of the buttons should raise the bow - lift tabs-push drives out. Get comfortable so you don't do it backwards while running.
Also, check for prop rotation. The boat is easier to handle if the props spin outward while your going forward. Enjoy your new toy and play safe. The props are currently set up to rotate out (looking towards the top of the prop)...based on everything I've read they'll stay that way.... |
While tabs are often run independantly to level out the ride, you always trim the drives together. The switch on the throttle runs the drives together and is like the rocker buttons, up trims the drives out, down trims them in. As for porpoising, I find the 336 hull to be pretty stable. My 272 would porpoise at cruising speeds enough that you had to drop the tabs just a bit to give the boat more running surface. The 336 seems to be better balanced and is pretty forgiving. |
looking good.. best of luck!
1 Attachment(s)
