HELP, Adhesive removal
Old 02-14-2005 | 10:02 AM
44MTI's Avatar
Default HELP, Adhesive removal
I have taken the mirrorred plexyglass out of my hatches but am having trouble getting all the adhesive off.I have been trying a plastic putty knife so not to scatch the fiberglass but it is going very slow.I think it is something called 5200.
44MTI is offline
Old 02-14-2005 | 10:12 AM
Ms PatriYacht's Avatar
Default Re: HELP, Adhesive removal
what about goo-gone, I use it on just about everthing, you can get a professional 32 oz bottle at Home Depot.
Ms PatriYacht is offline
Old 02-14-2005 | 10:21 AM
Wd-40 works also
LEOPAJM is offline
Old 02-14-2005 | 10:33 AM
offshoredrillin's Avatar
3M adhesive remover, can be bought at NAPA or any other auto place. Apply it let it work and soften the glue, then, use a hardcard/ Squeegee to remove the glue...
Rob
offshoredrillin is offline
Old 02-14-2005 | 10:38 AM
You might consider using 3M General Purpose Adhesive Cleaner P/N 051135-08984. Any store that sells paint and refinishing products for cars would have it. I'm looking at a one quart can. Pretty cheap too as I recall. It's worth a try. Good luck, sometime these things are tricky.
Lmarth is offline
Old 02-14-2005 | 11:08 AM
Bad news, 5200 was not intended to come off.
Good news, 3M Adhesive Remover will make it easier.
Gary
Gary Anderson is offline
Old 02-14-2005 | 12:32 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
What do you use to take adhesive off of teeth?
Maybe it will work on fiberglass
WARPARTY36 is offline
Old 02-14-2005 | 12:51 PM
Ron P's Avatar
Enjoy the show
Use Gas, the all purpose cleaner. Just don't smoke while your working.
5200 is a glue........ THE BEST GLUE.
Ron P is offline
Old 02-14-2005 | 01:27 PM
44MTI's Avatar
You maybe on to something. I have assistance do it at the office, so maybe I need to have them do this. It would definately make it easier for ME.
44MTI is offline
Old 02-14-2005 | 03:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
West Marine carries 5200 remover. Worked most excellant when I used it.
US1 Fountain is offline
