Question about pirelli flooring >
Old 02-19-2005 | 05:36 PM
Question Question about pirelli flooring
I need to buy a 7x7 full sheet of Pirelli flooring does anybody know where I can buy this??? What kind of glue should I use to seal the floor down with?? Should I seal the floor with something before I put the glue down? I got extremly lucky the old stuff came up in one piece!!
32 thunder is offline
Old 02-19-2005 | 06:05 PM
ATPatrick's Avatar
Default Re: Question about pirelli flooring
The biggest thing you need to do is get the larger 'gobs' of glue off so that when you install the flooring there are no lumps. 3M makes an 'Adhesive and Glue' remover that you can buy at an autmotive paint store. That works the best.
We purchase from LonSeal in California. I'm at home and the numbers is at the factory. PM me to remind me and I will get it for you on Monday.
All you are going to use for glue is 3M contact cement. Again, at the automotive store, 3M part number 8090. It's contact cement. That means you spray it on both the floor and the pirelli, let it dry and then stick it down. My guess would be two cans. But a third just in case.
Good luck! Pat.
ATPatrick is offline
Old 02-19-2005 | 06:12 PM
The sheet is 6' wide & any length you want. Like At Pat said use the Contact adhesive not Lonseals Gorilla snot. Do a search here on OSO , there's ton of info on Lomseal
Johno is offline
Old 02-20-2005 | 12:27 AM
Thanks, Pat good luck with the AT/Chief. Going to Florida on March 17 for 2 weeks at least. Maybe you could fit us in on a new 33 ride if your not to busy.
Jason 32 A/T
Old 02-20-2005 | 07:46 AM
instead of gluing directly to the floor , why not glue to a piece of closed cell foam and make it removable
open87 is offline
Old 02-21-2005 | 01:19 PM
Anymore ideas??
Igots
Cigarette
13
04-30-2008 10:14 AM
jmackin
Cigarette
6
11-18-2004 10:15 PM
KCHOTBOAT
04-16-2003 03:28 PM
Chris
04-20-2002 01:45 PM
Bad to the bone
03-21-2002 04:36 PM
