Speedmaster II's
Old 03-14-2005, 08:41 PM
phughes69's Avatar
Speedmaster II's
Who ever has speedmaster II"s, are the lowers on yours polished or painted? The lowers on mine have some kind of bondo substance filling the gap at the crescent (see pic) and the previous owner painted over the bondo with black paint. I would like to polish them, but I'm not sure how to blend in this part of the crescent into the rest of the bullet since the bullet is narrower than this part of the casting
phughes69 is offline
Old 03-15-2005, 08:45 AM
Default Re: Speedmaster II's
Sounds like you have TRS lowers with an added-on nose cone.
Edward R. Cozzi is offline
Old 03-15-2005, 09:38 AM
Hmmm, interesting. Like Ed said, is it a TRS or is the back taperd around the shaft.
If it is a II, it may have been damagedn and fixed. I dont think IIs were ever made in non-crescent lowers, like IIIs, but it could be a possibility. Then someone bondoed the crescent in. Anyone know of non-crescent IIs?
Otherwise all I've seen were bare aluminum.
Gary
Gary Anderson is offline
Old 03-15-2005, 11:28 AM
phughes69's Avatar
No they are speedy II's. The housing is tapered back around the propshaft. This filler piece seems to be wider than the housing, so I am wondering if I can grind it down and smoth it out to polish it. Also once it is polished, what can I do to keep it from oxidizing. The boat stays on the trailer when ever I am not using it.
Old 03-15-2005, 08:50 PM
phughes69's Avatar
here are other pictures. The area in question is circled in red on the last picture
Attached Thumbnails Speedmaster II's-engine-removal-69-.jpg   Speedmaster II's-picture-393.jpg   Speedmaster II's-outdrive-lower-housing.jpg
Old 03-15-2005, 09:53 PM
nice drives, rare! how high is the X? TRS metal is thin, if you spend the time to DA or sand the case then polish you may run the chance of thinning the metal, not the same metal as #3s or higher. keep them black less hassel and look better over time
TOASTY is offline
Old 03-15-2005, 11:16 PM
Offshoreracr's Avatar
I thought that Mercury Racing always said that polishing the lowers on SSM's slowed them down and that the surface being a little rough helped break them loose.
Offshoreracr is offline
bigo181979
Drives and Lower Units
41
08-22-2008 06:53 PM
DALLAS
3
04-18-2008 10:19 AM
seabeach
23
01-10-2005 11:28 AM
phughes69
Fountain
0
09-16-2004 10:49 PM
RUSSSR1
15
06-23-2004 09:33 AM
Quick Reply: Speedmaster II's
