need advice on garage size >
Old 03-27-2005 | 10:06 AM
Default Re: need advice on garage size
Where in Cape Coral are you putting that??
Mike 35 Fountain is offline
Old 03-27-2005 | 11:01 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
My garage is 48' deep. Just right for my 32' with a little room to spare on the ends. Takes the full 8' tall door to get'r in, so I am limited to the size and make of the boat just do to the door height. A couple buddies have a 34PQ and 35 Cig, they need 9' doors to enter. The door height will be your biggest obsticle for an attached garage.
US1 Fountain is offline
Old 03-27-2005 | 11:09 AM
Steve H's Avatar
artselectricinc.com
Mine is 50' long. If I want to work on my 42' Harley I must open the door and pull it out a few feet. Works O.K. for storage.
Steve H is offline
Old 03-27-2005 | 11:30 AM
hugetime1's Avatar
it is in ny
hugetime1 is offline
Old 03-27-2005 | 11:41 AM
Wildman1's Avatar
My garage is 48' widex105' long big enough for the boat, race car ,race car trailer, gator, two John Deere tractors, one Monte Carlo show car and another Monte Carlo in off frame restoration right now. This leave me enough room to still wash the pull truck when it gets dirty. Oh I forgot it also has a office with a full wet bar and a full bath plus satellite TV all air condition when it gets hot outside. Plus a couch when you get tried from working on everything so you can lay down and take a nap. The old saying goes " The guy with the most TOYS wins"
Wildman1 is offline
Old 03-27-2005 | 11:48 AM
If you have the room .........it's cheaper to do it now than add on later.
GO BIG.....
Old 03-27-2005 | 12:14 PM
timewarp's Avatar
A good rule of thumb is the garage needs to be at least 12' longer than the boat you want to store in it. A 36' boat with a Trailer with Drive guards will just fit in a 48' stall, if you want room to work around it you will need more length.
That said Bigger is better.
timewarp is offline
Old 03-27-2005 | 12:35 PM
VIPER7's Avatar
Depth and door height are the two major concerns with a boat. When I first built my garage 15 years ago with 42' depth and 10' doors I had plenty of room for my 26' Mirage. I bought a 35' 8" Sonic last year and I had to put a 2' telescoping tongue on the trailer in order to have room enough to walk around the boat. The 10' doors only leave about 1' of height clearance. If you need the extra depth or contemplate needing the extra depth for boat length, design the garage where you would have a stall in the garage with additional depth. I f you design it right you could build it that way now or add the extra depth later.
VIPER7 is offline
Old 03-27-2005 | 01:42 PM
redfountain420s's Avatar
My front door is 16x9 and i had to take the radar arch off also to get it in there.make sure you go wide enough to start because if you add on later its easier to buy the same size trusses and just go back
redfountain420s is offline
Old 03-27-2005 | 03:59 PM
Figure out what you truely need......then double it - then you'll be fine.
RebarBox is offline
