need advice on garage size >
Old 03-27-2005 | 04:58 PM
GLH's Avatar
GLH
Default Re: need advice on garage size
30x40 should be big enough for that 26ft Hustler...
GLH is offline
excursion's Avatar
In the process of building mine now, 40x80 , with 10x12 doors and 14' high ceilings. Travel lift to pull out motors is 12' tall, make the doors wide enough for what ever????
excursion is offline
Old 03-27-2005 | 07:23 PM
built mine last year , 30' wide 40' deep , 12' foot in the center with 4 - 10' tall 12' wide doors. 4 doors are great for breez control. 28 cig has plenty of room. 40x60 would be real nice but that is a big building. going steel or cinder block?
open87 is offline
Old 03-27-2005 | 07:41 PM
Official OSO boat whore
What kind of a building are you looking to put up? If you don't want to spend the money right now, at least plan for the future. I currently have a 30'x50' building and it's too small. It's amazing how fast one fills up. It really is. I would recommend a 40' width as being the minimum. My 30' works, but it's hard to get past two rows of stuff with the work benches and storage along the walls. So start with the 40' width and go as deep as you budget allows. Set the building off the setback line so you can expand back later. These buildings are very easy to add on to so the cost increase won't be too dramatic. Regarding ceiling height, I have 14' and would have gone higher if possible. By the time you hang lights and heaters, the head room can start to get low. My door is 12'x12' and I'm very happy with the size. Could have been 10' high and still worked.
Cord is offline
Old 03-27-2005 | 08:15 PM
Perfectmix's Avatar
[QUOTE=timewarp]A good rule of thumb is the garage needs to be at least 12' longer than the boat you want to store in it. A 36' boat with a Trailer with Drive guards will just fit in a 48' stall, if you want room to work around it you will need more length.
That said Bigger is better.[/QUOTE
I built a 40x48 14' sidwalls and 14wx12tall doors. My 357 on a trailer with drive guards is a snug fit. If I could do it over it would be a 40x60. That would have been perfect. Good luck.
Perfectmix is offline
Old 03-27-2005 | 08:31 PM
Sean H's Avatar
A to Z
the biggest that will fit on your lot......
Sean H is offline
Sean H's Avatar
A to Z
then buy the next bigger lot.....
Sean H is offline
Old 03-27-2005 | 09:22 PM
Top Banana's Avatar
Bigger is better,
The guy with the most toys wins, etc. etc.
Did you ever hear this one.........?
HE HAS THE MOST
WHO IS MOST CONTENT
WITH THE LEAST
Top Banana is offline
Old 03-27-2005 | 09:54 PM
dykstra's Avatar
Never big enough!
dykstra is offline
Old 03-27-2005 | 11:00 PM
outriggers's Avatar
I have a 2 car garage on the house and a 40x50 building and my everyday driver still sits outside. It should have been bigger. Doug
outriggers is offline
