need advice on garage size >
Old 03-27-2005 | 08:32 AM
hugetime1's Avatar
Default need advice on garage size
I am building a new home, and I currently have the plans being drawn with a garage that is 30' wide by 40' long, is that big enough??????
hugetime1 is offline
Old 03-27-2005 | 08:44 AM
Thunder Valley's Avatar
Cool Re: need advice on garage size
It's NEVER big enough !!!!!!! I just built mine 32' wide ad 48' deep, and the boat ( 38' Scarab ) filled one side quick and the rest filled up just as fast. Already need more space
Thunder Valley is offline
Old 03-27-2005 | 08:50 AM
Default Re: need advice on garage size
Not really close to being big enough! You have to do as big as you can do...it is more important than the house!
Byrdman is offline
Old 03-27-2005 | 09:04 AM
redfountain420s's Avatar
there never big enough , mine is 28 x 42 which was fine for the 30ft scarab but now i have a 40ft fountain and had to pull the drives and tabs and tounge off trailer just to get it in for winter.
Attached Thumbnails need advice on garage size-fount-back-garage.jpg   need advice on garage size-fount-beak.jpg
redfountain420s is offline
Old 03-27-2005 | 09:19 AM
hugetime1's Avatar
thanks, how tall are your doors, to get that thing to fit, cuz my boat will probobly be as tall, I am probobly getting a hustler cheetah, 34'
Old 03-27-2005 | 09:26 AM
Formula Outlaw's Avatar
100x200 ought to do it. Just be sure you leave room for expansion.
Formula Outlaw is offline
Old 03-27-2005 | 09:29 AM
wicked tunnel's Avatar
40x60 is a great size to build.
wicked tunnel is offline
Old 03-27-2005 | 09:45 AM
Big is Good, Bigger is Better.
In Fl you may want to have a strorage shed for the boat. Taxes on a shed might be cheaper. Sometimes, I don't like all my eggs in one basket, as fire would wipe out everything and it is harder to heat and cool.
Much of that depends on your lot size and access and womans input. Just make sure you make it really big. Incremental square footage is cheap. Adding on is expensive.
vonwolske is offline
Old 03-27-2005 | 09:46 AM
My 38' would actually fit in an 8' door, but I put 9' doors for plenty of clearance.It can also depend on the trailer how high it sits.I would go a min. 9 foot.
Old 03-27-2005 | 10:03 AM
mopower's Avatar
Toxic FORMULA
Go as big as you can afford or the law will allow. I've never built one that was big enough yet
mopower is offline
