Homemade bolsters
Old 03-31-2005 | 10:32 AM
lakeluvr's Avatar
www.sunriseuph.com
Default Re: Homemade bolsters
I'd say pretty good for a first attempt as well. There are lots of tricks that can be learned from experience and I'm sure you learned some already. Too bad you're so fare away, I'd give you a job.
Good luck on your other projects.
John
Sunrise Upholstery
www.sunriseuph.com
lakeluvr is offline
Old 03-31-2005 | 11:32 AM
bryanspeedracer's Avatar
Thanks John.
i wasn't so far away, I'd work for ya'. I need the practice.
bryanspeedracer is offline
Old 03-31-2005 | 12:23 PM
Zanie's Avatar
WOW!
First Transom core replacement, then upholstery.
Talk about tackling stuff that most people wouldn't even consider doing themselves.
What's next?
That 10 meter is gonna be cool!
What kind of sewing machine and needles do you need to use to sew that stuff?
Nice work!
DS
Zanie is offline
Old 03-31-2005 | 12:31 PM
AugiePensa's Avatar
Looks Great. Congrats!
P4-13 Team THE JERSEY BOYZ OFFSHORE POWERBOAT RACING, OPA/ SBI/APBA/UIM. PRESIDENT: THE JERSEY BOYZ , VICE-PRESIDENT: OPA RACING, THE GREAT SOUTH BAY RACING ASSOCIATION. WAZZUP RACING ENGINES
AugiePensa is offline
Old 03-31-2005 | 02:07 PM
88Fount33's Avatar
Beak botr
Originally Posted by bryanspeedracer
Actually, I just spoke with a local guy that could make bases and swim platforms.
My question is aluminum acceptable (Painted/powdercoated) or does it have to be stainless?
My 02 is that you have to mount the base using SS screws, aluminum and ss don't play well together unless you do a good coating and then have to make sure the screw does not tear the coating when tight. I really wanted SS supports but had to settle for coated. Used a nylon insert and washer to isolate the screw from the coated parts, but then I'm in salt water alot, for freshwater it would not be as important to spend the bucks. Lets see, so far my boat mine came with: nickel plated hatch hinges, sink dump, bilge pump dumps (2), niclel plated fuel fills and vents (2)aluminum bolster supports with SS screws, I don't know if the new ones come with this junk but it is not good for salt water. However, not to slam fountain, but another really really expensive boat built here uses powercoated aluminum bolster supports and SS hardware, and you would think for the $350K min purchase price they would do better. (I discussed making SS at the same shop that fabs "theirs", thinking it must be powdercoated SS but suprise!!!
88Fount33 is offline
Old 03-31-2005 | 03:26 PM
Zanie,
My last feat after the cockpit is going to be the cabin and then I'm done. I used a sewing machine marketed by Sailrite. Basically, it's a Brother (metal case) rebadged. I would guess that it is medium duty. I've seen some that are light and I've seen some in upholstry shops that are heavier duty.
Old 03-31-2005 | 07:02 PM
Bryan...nice job , they came out pretty good!
kaamaman is offline
Old 03-31-2005 | 07:05 PM
Thanks, bud. Your machine worked well.
Old 03-31-2005 | 07:21 PM
t500hps's Avatar
21 and 42 footers
Sure, do they need to be let out?
LMAO........and NO!
t500hps is offline
dean51267
04-21-2006 08:22 PM
cjsdad62
10-14-2005 09:10 PM
