Truck Hitch Info Needed
Old 04-04-2005 | 08:08 AM
  #31
GLH's Avatar
GLH
Default Re: Truck Hitch Info Needed
Your all set ... keep the boat light... besides why keep 280 gallons of gas in that pig I'll be that much faster than you then...
GLH is offline
Old 04-04-2005 | 08:12 AM
  #32
drypipetiger's Avatar
Exactly GL.... For my needs its weight carrying and it saysright on the hitch weight carrying - #7500.
drypipetiger is offline
Old 04-04-2005 | 02:17 PM
  #33
the only problem with the factory hitchs is they will break. A good friend owns a trailer repair shop here in Oklahoma and had a trailer to redo because the hitch broke, not the bolts or the drop part but the actual hitch where the drop slides in, not his first to see this happen on.
JPD Motorsports is offline
Old 04-04-2005 | 03:36 PM
  #34
t500hps's Avatar
21 and 42 footers
Originally Posted by bajaneil
Spoke with the current owner this morning. He tows with a GMC 2500 GAS......
Yeah, but I believe he has the 8.1 w/ 465 lbs of torque. Not quite a diesel (duramax is 560???), but enough azz to move that pig!
t500hps is offline
Old 04-04-2005 | 04:27 PM
  #35
that Titan does install closer to the bumper (frame height) on a Ford it seems.
I'm glad it came with good hardware. Though I feel the hardware bit is a good heads-up for everybody. Mine could have been 8's but not cad-plated, and not long enough to run bigger thicker backer plates and double nut.
again, if I was towing the next level in wieght/size, as you are Trout...I would most likely have chosen the Titan for twice the money.
but for the $$ I feel my needs are met quite well. Especially over the stock GM paperwieght.
I still like the idea of the crossmember running out through/well beyond the plates like they do on the XDR... quality welding work included.
Luv u 2 brudda...
BTW, can you believe the performance of that 496 353 of Robert's?
Rippem is offline
Old 04-04-2005 | 07:18 PM
  #36
I am looking forward to installing some new muff (s) very soon.
Rippem is offline
4mulafastech
12
09-07-2005 10:35 PM
Hi-Tech Marine
General Racing Discussion
2
07-06-2004 12:10 PM
TEAMBAJA
11-16-2003 08:53 PM
Flyinbrian
02-05-2003 07:41 PM
Audiofn
05-09-2002 01:23 PM
