Help!! might have bought the wrong prop!! >
Old 04-13-2005 | 11:38 PM
hillbilly24's Avatar
Default Re: Help!! might have bought the wrong prop!!
hes only a basic member so he cant posta picture anyway, or see yours for that matter
hillbilly24 is offline
Old 04-13-2005 | 11:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Is this anything like you have?
http://www.cyber-bridge-marine.com/S...?CategoryID=62
US1 Fountain is offline
Old 04-14-2005 | 07:10 AM
Is this a older Mirage solid hub 25? Like from the early 90's? If so, it probably has a part # on the prop like 48-13248A50 25P
If that is the case the thrust hub you are looking for is a Mercury part # 14359
Been there done that. I have thrust washer and the same prop for sale if you need a spare
see attached pic.
Attached Thumbnails Help!! might have bought the wrong prop!!-thrust-washer.jpg
1BIGJIM is offline
Old 04-14-2005 | 07:44 AM
looks like big jim might be right, it's the same p/n prop that i bought. do i need to get two different washers, front and back, or just the big thrust washer??
cloudmaster_321 is offline
Old 04-14-2005 | 08:29 AM
throttleup's Avatar
Measure the hub housing from the outside diameter. This is an old part number, 48-13248-25. I believe what you have is an old style solid hub mirage. If so the thrust washer is indeed different and 1BIGJIM would be correct.
Julie
throttleup is offline
Old 04-14-2005 | 10:41 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Help!! might have bought the wrong prop!!
Your prop does require the
#14359 Thrust Hub
If you need help getting one we have them.
920-295-4435
bbladesprops is offline
Old 04-14-2005 | 12:39 PM
i picked up that new thrust washer at a local mercury dealer, but do i use the same thrust washer on the nut side. Looks like this one is stepped to fit into the 23p, and it would just butt up against the 25p??? thanks for the help guys
Old 04-14-2005 | 12:56 PM
On the back/nut side use the castellated splined washer, a tab washer and the nut torqued to 55 ft/lbs.
Old 04-14-2005 | 03:12 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
some time the small old style thrust washer will fret onto the prop shaft tight enough that it apeears to be a part of it.
The prop shaft should not appear to have any shoulder on it if it does it is the old thrust washer and needs to come off.
klaw is offline
Old 04-14-2005 | 06:06 PM
Quiet Storm's Avatar
Wipe the grease off the shaft and take a close look at the spline. Check to see if it has a slight twist in it. I had the same problem when I went from a B1 to a Hydro Q4. I couldn't get it to go on that last little bit.
I replaced the shafts and then everything fit fine. My wallet fit in my pants better too because it had less in it.
Quiet Storm is offline
