Lost 400 rpms on both motors from one week to the next >
Old 04-18-2005 | 12:41 PM
MillerLite88's Avatar
Charter Member # 90
Default Lost 400 rpms on both motors from one week to the next
Last weekend I was able to get my 496HO's up to 5000 rpms and this weekend I could only manage 4600rpms. This seems to have cost me about 3 mph and I am just wanting some feedback from you on what you think the problem may be. The temperature was exactly the same the previous weekend as was Saturday and Sunday.
-Shoe
MillerLite88 is offline
Old 04-18-2005 | 01:04 PM
zt260's Avatar
Default Re: Lost 400 rpms on both motors from one week to the next
-Shoe
It this boat docked? Bottom growth can shave a few mph.
zt260 is offline
Old 04-18-2005 | 01:10 PM
WHOSNEXT's Avatar
Trim up? was the trim the same?
WHOSNEXT is offline
Old 04-18-2005 | 01:24 PM
Charter Member # 90
The boat was not docked fromt the first week to the next and yes the trim was the same. I have no idea??? I have heard about the 496's having all kind of sensors going bad and only allowing so many rpms but I would think that this is not the case at 4600 rpms.
-Shoe
Old 04-18-2005 | 01:53 PM
zt260's Avatar
More gas or people on board.
Props damaged
Is your speed via GPS or speedo?
zt260 is offline
Old 04-18-2005 | 02:09 PM
Charter Member # 90
Approximately same gas(within a few gallons) and then later in the day it would have been less fuel this versus last. Same two people on board and there is not a ding on a prop. I may have gained a few pounds in a week but this is frustrating.
-Shoe
Old 04-18-2005 | 02:19 PM
Is it possible that you hit the rev-limiter last week-end and the engine is now stuck in safeguard mode - where it operates at 90%?
bouncedcheque is offline
Old 04-18-2005 | 05:57 PM
BBB
rev limit does not go to limp mode. before starting the engine turn key to run but do not start, listen for 5 sec. for the warning beep to beep once then if you have a sensor falt ( causing power derating) then you will hear aditinal 2 or 3 beeps after the inital beep. I had a water pressure sensor go out and then a exhaust water temp sensor go out and this is what mine did.
BBB is offline
Old 04-18-2005 | 08:36 PM
Question Re: Lost 400 rpms on both motors from one week to the next
BBB is probably right. If the motor has a fault code in the ECM that is set and not cleared, depending on the code it can put the motor in a 90% only power mode which would account for the possible lost rpms and speed. Have someone or a dealer with a scan tool read the ECM and verify its running a 100% power level. Its probably a minor problem since your not in a fault mode that cuts power to 60% or 10% which is the limp home mode.
good luck,
Ray @ Raylar
Raylar is offline
Old 04-19-2005 | 08:47 AM
Charter Member # 90
Thanks guys and I could understand that if it was just one motor but both at the same time??? I do have a buddy with a lap top and scan tool that plugs into the ECM. I will give that a try.
Thanks,
-Shoe
