Trans slipping again >
Old 04-18-2005 | 01:48 PM
BBB
Default Trans slipping again
Need help diagnosing this one. I am running BW 10-17 trannys behind 8.1 HOs. after replacing forward clutches with graphite, new seals and rings, the port trans goes away, 3 times now. I was wondering what kind of pressure I should be getting out of the pump, and where do you tap for that test and what rpm ect. Thanks.
BBB is offline
Old 04-18-2005 | 04:03 PM
Default Re: Trans slipping again
Check your dip stick length in trans. may be to long and you are running on low oil. I had similar problem with trans. stick was cause. Good luck
hytech is offline
Old 04-19-2005 | 11:40 AM
BBB
Thanks but the level is good, I am thinking it may be in the relief valve but I dont have any specs to go buy, any knowledge in this area would be greatly appreciated,
BBB is offline
Old 04-19-2005 | 12:07 PM
Panther's Avatar
Frank's Marine Service
what kind of oil are you running??? Regular ATF isn't good, you should be using Type-F trans fluid with those clutch plates.
Panther is offline
Old 04-19-2005 | 01:53 PM
BBB
type f fluid and also using Huber forward clutch apply pistons
BBB is offline
Old 04-19-2005 | 08:41 PM
If you don't hear anything here, try these guys... they're very helpful too.
http://www.marinegears.com/techboard/
jackhammer is offline
Old 04-21-2005 | 02:38 PM
BBB
Ok so I ran the engines on the hose and did transmission pressure tests. idle 130 psi, 1500 rpm 160 psi, also pulled the control valve and dissasembled the pressure relief valve and found it to be free and in good condition, the trans that is not slipping has the same pressures, please help me before I go crazzy and buy a jet ski.
BBB is offline
Old 04-21-2005 | 07:13 PM
dykstra's Avatar
Now don't go off the deep end and buy a jet ski!
dykstra is offline
Old 04-22-2005 | 02:18 PM
What drives are you running and do you have nose cones? Had a minor chip in nose cone filler and at speeds at about 75 mph. started to act as if trans. was slipping. Would never have guessed such a minor defect would have caused such a prob. Pulled trans. and found no prob. I can understand your frustation.
hytech is offline
Old 04-22-2005 | 05:43 PM
BBB
yes nose cones on trs, but no prop slip, had that before and can recognize that, and on every tear down forward clutches are burned.
BBB is offline
