beep alarm at 5150 on a 350 Mag Mpi.  what is it? >
Old 04-20-2005, 07:07 PM
Default beep alarm at 5150 on a 350 Mag Mpi. what is it?
I had my alarm beeping at me when I was testing a prop this weekend. I was reaching my rev limit, and I thought that was what it was, but I talked to my boat mechanic and he said that the alarm only goes off for temp. or low drive oil, not rev limits. I know I was running right about 5100-5150 r's, and I just assumed that the beeping was the rev warning before the limiter actually made the motor cut out. ( it actually never cut out, so I must not have quite reached 5150). My oil pressure, and temp were fine. I was wondering what else the beep was telling me? Any suggestions? This is on a 350 Mag Mpi, 2002 about.
justinVIP is offline
Old 04-20-2005, 09:09 PM
Smitty's Avatar
Default Re: beep alarm at 5150 on a 350 Mag Mpi. what is it?
If you were showing near 5100 then you were at the rev limit. The tachh is usually a little behind the module in revolution counting.
Smitty is offline
Old 04-20-2005, 09:24 PM
Mentalpause's Avatar
My Livorsi gauges don't beep at the rev limiter, but I have a friend with Faria guages that do beep when he hits the rev limiter. Not sure it has anything to do with the guages but it just depends on how yours is set up.
His old boat did the same thing.
Mentalpause is offline
Old 04-21-2005, 07:03 AM
Anyone else know if the alarm will beep if I am hitting the rev limit? 1995 2102 VIP Victory with a 2002-3 350 Mag MPI, Alpha drive. Thanks, J.
Old 04-21-2005, 07:30 AM
My 99 did until I sent the ECU to ASM and had the rev limiter removed.
Plane Silly is offline
Old 04-21-2005, 03:01 PM
BBB
my 8.1 HOs beep continuously if i am at rpm limit then goes off when I throttle back
BBB is offline
Old 04-26-2005, 08:05 AM
Thanks guys.
Steve H
9
06-20-2008 12:08 PM
brick1932
7
09-21-2007 08:07 AM
Reckless32
54
07-03-2007 11:24 AM
Jeff Pierpont
1
06-04-2004 08:12 PM
justinVIP
17
11-18-2003 10:43 AM
Quick Reply: beep alarm at 5150 on a 350 Mag Mpi. what is it?
