What Octane to use on 496? >
Old 04-22-2005 | 11:32 AM
saubouin's Avatar
Default What Octane to use on 496?
I always like err on the side of safety (better oils, filters etc...) This is only my 2nd season as a boater, and will be my first full season. I've been filling up with nothing but 92 octane on a 100% stock plain 496 (375hp). Am I just pissing away money here? Seems to me with detonation/piston design issues with this motor it just seems safer. Also are their knock sensors on these things?
Would appreciate everybody's opinion on this.
TIA!
saubouin is offline
Old 04-22-2005 | 11:35 AM
Macklin's Avatar
Default Re: What Octane to use on 496?
Do not use 92! The motor/computer is designed to run on 87. They don't like 92. You are definitely pissing money away.
Macklin is offline
Old 04-22-2005 | 11:36 AM
Yes you are pissing away money! And I bet there is soot on your transom to boot.
Use the recommended 87, save money and give the computer what is was designed for.
LHC30Victory is offline
Old 04-22-2005 | 11:39 AM
saubouin's Avatar
No excess soot at all on the transom. How would the 92 octane gas be bad for the computer?
saubouin is offline
Old 04-22-2005 | 11:56 AM
saubouin's Avatar
WOW, this feedback is an eyeopener. How does 87 octane fuel burn faster than 92? I'm confused.
saubouin is offline
Old 04-22-2005 | 05:35 PM
hillbilly24's Avatar
The basic concept is that the higher the octane the more resistent to burning the fuel is, thats what the octane rating is all about. If you run a fuel that burns slower then a motor is setup for it may not be able to componsate the timing and injector pulse width adequatly within the preset perameters in the ECM.
hillbilly24 is offline
Old 04-22-2005 | 08:51 PM
Dave M's Avatar
Veteran: Navy
I use 87 in mine, no problems. That's what Merc says to use.
Dave M is offline
Old 04-23-2005 | 07:50 AM
Macklin's Avatar
I am surprised at that. My transom goes black when I am forced to put 92 in. We convinced my marina to start carrying 87 instead of 89 for this reason. I noticed a difference even then.
Macklin is offline
Old 04-24-2005 | 04:30 PM
Use 87 octane like Merc says .
Saw something in Hot Boat mag a few years back where they ran a dyno on an 502 EFI . They ran 92 then 87 and saw HP go down with the higher octane . Had something to do with the computer making adjustments for the higher octane .
Greggcellent is offline
Old 04-25-2005 | 06:27 AM
saubouin's Avatar
Thanks a bunch guys! I will be filling up with 87 from now on.
BTW, does the 496 MAG have a knock sensor that automatically retards timing if knock is present?
Again thanks for all the great feedback.
Sebastien
saubouin is offline
