Will Hydralic valve lifters too tight affect oil pressure >
Old 05-01-2005, 09:40 PM
Default Will Hydralic valve lifters too tight affect oil pressure
A couple of years ago when I rebuilt my sbc I adjusted the hydralic lifters cold. I did a compression check after adjusting them and had 160 in every cylinder. Is it possible that too tight lifters will cause low oil pressure?
I may try to adjust them running where you loosen them until they make noise and them tighten them a half turn.
Is it possible to have a lifter a little tight and loose oil pressure?
thanks
FlyFast is offline
Old 05-02-2005, 01:30 AM
articfriends's Avatar
Default Re: Will Hydralic valve lifters too tight affect oil pressure
NO,you could burn a valve or bend/break one on piston but no way should it affect oil pressure. I have seen alot of guys put small blocks in boats and not use a oil cooler which could/would give you low oil pressure hot,are you running a engine oil cooler? Smitty
articfriends is offline
Old 05-02-2005, 07:52 PM
Smitty,
You are right. My alpha drive 350 from the factory never had a oil cooler. I still do not have a oil cooler and I know that would help. the oil pressure is fine cold and this is an engine hot problem. I run closed cooling and just went back to a 140 t-stat to keep the engine and the oil a bit cooler.
The motor runs good. My first motor had a exhaust valve seat fall from the head into the engine. The second build was short lived and this the third motor has lasted for a couple of years. On the third build i did have the crank cut and I think I am loosing oil presure some place else.
the other thing I do have a high volume oil pump. I have heard that some of these will put out a little lower oil pressure at idle.
the low oil pressure started with the high volume oil pump.
the motor is a vortec 355.
thanks
FlyFast is offline
cmd1962
2
11-05-2007 03:50 PM
allenk4
7
08-09-2007 07:15 AM
dykstra
4
08-13-2005 08:29 AM
articfriends
7
02-02-2005 08:30 PM
FlyFast
3
05-08-2004 08:16 PM
Quick Reply: Will Hydralic valve lifters too tight affect oil pressure
