Throttle Cables - who makes the best? >
Old 05-04-2005 | 12:15 PM
p4-33's Avatar
Default Throttle Cables - who makes the best?
I'm installing new controls, and need to buy some new cables. Who makes the best ones, slickest, good wear characteristics?
It's a pretty straight shot, so I won't be doing any tight radius's.
Thanks,
Brian
p4-33 is offline
Old 05-04-2005 | 12:21 PM
Strip Poker 388's Avatar
Rob
Default Re: Throttle Cables - who makes the best?
Thanks,
Brian
I would like to know also.
Also with less strech,and no slack
Rob
Strip Poker 388 is offline
Old 05-04-2005 | 12:36 PM
hillbilly24's Avatar
I've found the merc platnium cables to be about the best on the market. They have two lines, the standard and the platnium. The platnium or larger in diameter and have zero resistance. We installed alot as drive indicator cables too wich leeves the end prett much open to saltwater except for the little rubber boot, and we didn't see any problems with them even in this configuration.
hillbilly24 is offline
Old 05-04-2005 | 01:22 PM
Ted G's Avatar
Teleflex TFXtreme, absolutely the best out there. Smooth, no slop, and very strong.
www.cbpba.com
Ted G is offline
Old 05-04-2005 | 08:13 PM
p4-33's Avatar
Thanks Ted,
I see they're available in 1' increments, too. That's a plus.
Brian
p4-33 is offline
Old 05-04-2005 | 08:20 PM
Ted G's Avatar
Oh, one drawback to the TFXtremes- If you have a very tight run or gap to run them through be aware that they are almost twice as thick as a regular cable. However they will make a a nice tight bend if need be.
www.cbpba.com
Ted G is offline
mv35
Swap Shop
0
08-10-2008 08:27 PM
gripit
21
05-14-2005 09:49 PM
MnFastBoat
2
06-20-2004 08:23 PM
masi242
4
04-13-2004 08:53 AM
blown formula
5
01-28-2003 01:27 PM
