1998 454 Mag Engine Scanning >
Old 05-06-2005 | 05:22 AM
CMC
Default 1998 454 Mag Engine Scanning
Does any one know if a Mercruiser Scan tool can retrieve information from a 1998 Mercruiser 454 Mag ?
CMC is offline
Old 05-06-2005 | 07:17 AM
t500hps's Avatar
21 and 42 footers
Default Re: 1998 454 Mag Engine Scanning
Not sure, but had someone hook a computer to the ecu's of my 98 502's last month and it only gave us a little info. Mainly just confirmed the hour meters were correct, but no running history on RPM's etc.
t500hps is offline
Old 05-06-2005 | 08:14 AM
Poorsche's Avatar
I've got 96 vintage MarinePower 454's with Arizon Speed EFI. The MEFI's are MEFI I. My RINDA Tester reads all the codes, diplays all the data and performs all the diagnostics.
Poorsche is offline
Old 05-06-2005 | 09:51 AM
Dave_N's Avatar
The Merc scan tool will connect and read data from any Merc EFI engine made in '98. You can get an adapter to read operating hours on carbed Thunderbolt V systems as well.
As t500hps said, a MEFI 1 system will not give a break down of operating hours, just the total.
Dave
Dave_N is offline
Old 05-06-2005 | 10:33 AM
Poorsche's Avatar
My RINDA gives total hours from MEFI 1--
Poorsche is offline
Old 05-06-2005 | 07:33 PM
DORaymond's Avatar
I have a Rinda scan tool and have used it on my 2000 502's and have not been able to retrieve detailed operating hours for each RPM? It loes report all codes and other operating parameters.
DORaymond is offline
Old 05-06-2005 | 08:58 PM
Vinny P's Avatar
I hate the winter!!
I have the QuickSilver scanner, it will retrieve all the data you would need.
Vinny P is offline
Old 05-06-2005 | 09:19 PM
DORaymond's Avatar
On a MEFI-3 do you obtain the breakdown of operating hours at each RPM range from the scanner via the MEFI-3, or must you connect it somehow to the ignition?
TufEnuf
07-01-2007 11:22 AM
mark30h
2
10-07-2006 03:23 AM
MC-BOYS
Powerquest
7
05-16-2006 07:44 PM
26sonic
1
05-29-2003 08:45 AM
RussB
2
03-19-2002 09:02 PM
