paging houston prop >
paging houston prop
paging houston prop
Old 05-08-2005 | 04:53 PM
Default paging houston prop
my 32 active thunder w/ 500s spins my bravo 1 30 pitch props
5500 /5600 rpm at 85/86mph on gps. today i put on my 32 b1s and can only spin them 5000 rpms and 83 mph on gps.
can my 32s be worked to pick up 300/400 rpms and would i gain speed over my 30s.
thanks 32 thunder rick
if so appx how much and how long.
rssteiny is offline
Old 05-09-2005 | 06:17 AM
Default Re: paging houston prop
any insight would be appriciated.
rssteiny is offline
Old 05-09-2005 | 07:47 AM
BajaBennett's Avatar
rsstiny,
Call Julie @ Throttle Up. She will help you out with the right info. They do great work and they get it done when they say they will. They will work with you until you are happy.
Dail
BajaBennett is offline
Old 05-09-2005 | 09:08 AM
dykstra's Avatar
Julie and Matt are the best!
dykstra is offline
Old 05-09-2005 | 10:59 AM
What happened to Houston Prop? Are they still in business?
BadDog is offline
Old 05-09-2005 | 12:42 PM
what is the # for julie.
thanks
rssteiny is offline
Old 05-09-2005 | 12:56 PM
baja36ft's Avatar
727-531-2255
baja36ft is offline
Old 05-09-2005 | 04:44 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Might post this in the 'prop talk' forum
US1 Fountain is offline
Old 05-09-2005 | 05:33 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: paging houston prop
If your still looking for information on your set up, we can help. I must apologize for not paying as much attention to this forum as the prop forum.
Typically the decreas in rpm from the 30 B1's to the 32 is 400rpm. You lost a little more which isn't completely unheard of. I'm not sure about your rpm with the 30's since the rev limiter on HP 500's is 5400. Do you have a different program in your ecu?
Our Labbing thickness curve will deliver an additional 300 rpm in its standard version. We offer additinal curves that will give even more rpm. We would want to discuss your ultimate desires before suggesting that option. Even at 5300, with your currrent slip%, you should see a speed increase.
Call us if we can help. Thanks.
[email protected]
bbladesprops is offline
Old 05-09-2005 | 05:56 PM
BAD-HABIT's Avatar
Is Houston Props Still around???? Anyone?????
BAD-HABIT is offline
