Dual Carbs vs MPI on Blown motor????? >
View Poll Results: Blown or NA
Blown with MPI
8
29.63%
Blown with Carbs
16
59.26%
NA
3
11.11%
Voters: 27. You may not vote on this poll
Old 05-15-2005 | 06:32 PM
Default Re: Dual Carbs vs MPI on Blown motor?????
If you are on a budget go with the carbs. Not all of us can afford the FI
5.0willy is offline
Old 05-16-2005 | 06:48 PM
Originally Posted by NOBODY
This happens alot with single carb apps with a supercharger, and this problem may not be fuel delivery to the carb, but the fuel delivery through the carb via (jet size, needle and seat size, power valve orifice size, booster size and style, float drop, air bleed size, ect., ect. This is alot easier to accomplish with two carbs because you have double the amount of orifices and reservoirs for the same amount of air to move.
This sure seems like a lot of work versus setting up an EFI system, and then to double it with two carbs. I'll go along with Attack's comments about EFI electrical sensitivity, though. Mercury put a lot of work getting the corrosion problems fixed, I'm sure.
Michael
Michael1 is offline
BLOWN85
10
07-08-2008 06:41 AM
fastlane40
5
08-04-2007 08:54 AM
1stfntn
20
06-10-2005 12:54 PM
electrical1
5
07-05-2004 11:37 AM
DJD
11-15-2002 07:45 AM
