Set Timing?
What Should The Timing Be Set At ? The Motor Is A 509 With Fully Ported Heads And 9.5 Comp. Use Only
93 Fuel. |
Re: Set Timing?
What ignition are you running? plus, what ehaust are you running? When I build that type of engine I usually run 34 degrees total at 4000 RPM. If I think the customer is going to possibly get 89 or less fuel out on the water, I'll turn it back to a moderate 31 to 32 degrees. Dont need any melt downs !!
John |
Re: Set Timing?
John |
| All times are GMT -5. The time now is 10:22 PM. |
