EFI Gurus wanted >
EFI Gurus wanted
EFI Gurus wanted
Old 05-16-2005 | 07:15 PM
Dave_N's Avatar
Default Re: EFI Gurus wanted
Originally Posted by wallynt
This is what's puzzling me.When I disconnected the wire at the distributor the switch was not hooked up. I had cut the wire before the dist,stipped the ends, touched them together and started and ran the engine. While running I undid the connection and the engine kept running.
If thats the case, you appearently still have an open IC circuit, maybe not due to interrupt switch but due to a bad connection somewhere or possibly a bad ignition module.
Test the interrupt switch with a multimeter. Find out if it's normally open or closed. If it's the correct normally closed switch, I would install it and retest. It would really be helpful if you had a code tool, since open IC line will set a trouble code 42. I will post how to make a code tool in a new thread.
Dave
Dave_N is offline
Old 05-16-2005 | 07:23 PM
Dave.
I just checked the new switch with a muti meter and it is normaly open like you suspected. When I disconnected the wire when running this time it did kill the motor. I will pick up another switch tomorrow (normaly Closed) and try it again.
Thanks for all your help. I'll let you know what happens.
Paul.
wallynt is offline
Old 05-17-2005 | 05:52 PM
Post Re: EFI Gurus wanted
Dave.
Hooked up the new switch and it works fine. Just wanted to thank you for taking the time to explain the process and variables in detailed yet understandable terms.
Paul.
wallynt is offline
Old 05-17-2005 | 11:12 PM
Dave_N's Avatar
Glad I could be of help.
Dave
Dave_N is offline
Old 06-10-2012 | 04:59 PM
Sonny Spectre 30's Avatar
Dave,
Any idea of how to put together a shift interrupt switch for the Ilmor 625 engine?
Sonny Spectre 30 is offline
smokin' gun
Wanted
7
01-27-2017 05:59 PM
smokin' gun
Wanted
2
05-30-2008 07:00 AM
smokin' gun
Wanted
1
04-15-2008 11:27 PM
Inspector
Wanted
0
03-25-2008 08:56 PM
nordic95
0
09-19-2006 02:58 PM
