575SCi oil leak?  FOUND!!!! >
Old 05-19-2005 | 01:00 PM
Steve Zuckerman's Avatar
Default Re: 575SCi oil leak? FOUND!!!!
Hillbilly's correct as usual, except it's "BLADDER".
Whenever I change the oil in mine (575SCi) it has what appears to be a mixture of oil, fuel, and water in it. I made a suction device to draw the old crap out of the reservoir. Since I'm probably not getting it all, I now change it every other time I change oil @ 25 hrs. I think they all leak water and fuel into the oil reservoir.
Regards,
Steve
Steve Zuckerman is offline
Old 05-20-2005 | 06:52 AM
BillR's Avatar
OSO Moderator
Originally Posted by baja36ft
No Big Deal Bill Fix It And Lets Go Boating!!!!!!!!!!!!!!
You Should Change That Fluid Once A Year Anyway.
Stan
I hear ya Stan! All new parts should arrive today and hopefully get installed today. I'll take the old parts and try to figure out hou to rebuild them so this should never be a problem again.
Now if the dam weather would co-operate!!! I have NEVER seen such a cold, or wet, or blowin spring.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-20-2005 | 06:55 AM
BillR's Avatar
OSO Moderator
Steve, what did you come up with as a suction device? I am trying to invent one that will suck out not only that fliud, but the oil in the blower too. I was thinking along the line of a large syringe. But I need to figure out how to seal some thin flexible hose to it.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-20-2005 | 08:14 AM
Canada Jeff's Avatar
You can get a suction devise from any Auto parts store. Its not uncomon in auto mechanics.
Canada Jeff is offline
Old 05-20-2005 | 11:30 AM
Hey Canada,
Never thought of that. I guess it's too obvious , but I'll check it out. Bill, I made mine out of a old spray bottle tube and pump. The line can be bent to get down into those tight turns, like the oil reservoir on the fuel/water pump, which is a *****, and the oil resevoirs in the W256. It beats the hell out of taking these things off the motor to drain them.
Not technical, but essentially free and it works.
Regards,
Steve
Michael Garibay
0
06-02-2008 12:19 AM
Dkahnjob
Fountain
2
11-04-2007 02:29 PM
FOUNTAINFAMILY
6
10-25-2005 06:27 PM
zahndok
15
06-02-2005 11:54 PM
BillR
6
05-18-2005 11:03 AM
