575SCi oil leak?  FOUND!!!! >
Old 05-18-2005 | 11:01 AM
BillR's Avatar
OSO Moderator
Default 575SCi oil leak? FOUND!!!!
It was coming from my raw water pump!
My raw water pump is the type that also has a fuel pump attached. There is a small oil galley to lube the mechanical fuel pump. That gally was full full of oily fuel. I assume my fuel pump is leaking and presurizing the oil gally on the raw water pump. Also diluting the oil with fuel. I guess it has been going on for some time now. The I guess the fuel/oil mix worked out thru the seals and onto the motor. Both pumps have this problem!
2 new complete assemblies are on order!!!!
Anyone ever see this happem?????
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-18-2005 | 11:32 AM
Default Re: 575SCi oil leak? FOUND!!!!
I have seen that problem many times. It also does not do the water pump impeller any good. I usually run into that problem when putting a new impeller in the pump.
wrenchman is offline
Old 05-18-2005 | 12:21 PM
Quiet Storm's Avatar
Don't all the 502 blocks use the same fuel/water pump?
Quiet Storm is offline
Old 05-18-2005 | 12:26 PM
Cool Trips's Avatar
That happened on my 525SC's They had the old style water pumps with a cast rear cap that hooks to the water lines on a 90 degree angle. The new style pump is one piece (plastic) that connects straight out the back. I had to "customize" a few things to change the hose direction.
Cool Trips is offline
Old 05-18-2005 | 02:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
VERY common. My 500EFI did this.
Sydwayz is offline
Old 05-18-2005 | 02:21 PM
offshoredrillin's Avatar
On the 502's in my 311, there is a tube that is a tell tale sign, usually the gasket on the inside goes and allows fuel to get into that area, the gasket/bladder is an easy fix.
offshoredrillin is offline
Old 05-18-2005 | 03:27 PM
carney's Avatar
BillR, you might want to check the vent tubs under the spark arrester. A friend of mine had one of his fall out at wide open throttle. When he let off the throttle stayed wide open.
carney is offline
Old 05-18-2005 | 04:39 PM
Summer Heat's Avatar
Had the same problem on our 500's, just got it back last weekend. It will be nice to have a clean bilge after a run instead of that dang thing dripping.
Summer Heat is offline
Old 05-18-2005 | 06:47 PM
baja36ft's Avatar
No Big Deal Bill Fix It And Lets Go Boating!!!!!!!!!!!!!!
You Should Change That Fluid Once A Year Anyway.
Stan
baja36ft is offline
Old 05-18-2005 | 06:59 PM
hillbilly24's Avatar
you should change the oil in there once a year or more, every time you change the impeller, wich should be atleast once a year just change the oil at the same time. It just takes the same oil you poot in your drive. It always has fuel in it, I don't think I ever checked one at the shop that didn't. If you change it often enough you will be fine, if you let it run with the fuel in it you will run into trouble. It is a sign of a rupptured blatter in the fuel pump and you can change just the blatter. You are probably better off just buying a blatter every time you buy an impeller.
hillbilly24 is offline
