Prop install / assembly >
Old 05-19-2005 | 07:32 AM
Stormrider's Avatar
JC Performance Engines
Default Prop install / assembly
When I went to change my props, I noticed the 3 blade uses different hardware than the 4 blade that was on there.
Here is the 3 blade. I just don't know where this hub goes, and if it is inserted in the front of the prop, is there a specific way it goes in.
Attached Thumbnails Prop install / assembly-dsc00422.jpg   Prop install / assembly-dsc00423.jpg
Stormrider is offline
Old 05-19-2005 | 07:33 AM
Stormrider's Avatar
Default Re: Prop install / assembly
Here is the 4 blade. It had this hub assembly that was put in the back of the prop.
Attached Thumbnails Prop install / assembly-dsc00424.jpg   Prop install / assembly-dsc00425.jpg
Old 05-19-2005 | 07:35 AM
Stormrider's Avatar
Lastly, the thin metallic tab that gets put on before the prop nut, one of the small tabs broke off. Can this be used w/ just 2 of the tabs? even temporarily?
Old 05-19-2005 | 07:09 PM
Pat McPherson's Avatar
Hey Storm,
Your 3 blade looks to have a pressed in rubber hub and the 4 blade has the newer style insert.
Be sure to use a thrust washer behind either.
Yes you can use the locking devise with a tab missing. It really only requires that you bend one tab to prevent rotation...
Patrick
Pat McPherson is offline
offshoredrillin
Wanted
12
01-04-2008 02:02 PM
sonic28
Drives and Lower Units
4
08-12-2007 12:48 PM
riski bidness
1
05-02-2006 12:55 PM
Stormrider
Prop Talk
0
05-19-2005 08:25 AM
Waterfoul
07-24-2002 11:24 PM
