Active Thunder Extension box, Prop, Listing to port? >
Old 05-19-2005 | 09:24 PM
Default Active Thunder Extension box, Prop, Listing to port?
I have a 2000 28 foot Active Thunder Savage With 500efi. I'm experiancing a list to the port at most all speeds in calmer sea's and porpoiseing, Im wondering about going to a right hand prop maybe 5 blade, Any sugestions? Also has anyone ever tried an extension box on one of these boats?
ghaskell is offline
Old 05-20-2005 | 11:57 PM
Default Re: Active Thunder Extension box, Prop, Listing to port?
I had a 12" stelling box on a 25' Active thunder Tantrum which I removed because I thought that it would help with porpoising. It didn't really make a difference. In my case I seemed to pick up some speed and the porpoising remained the same. I purchased another Barvo 1 and had some work done on it by Merc and that seemed to help me a lot. I didn't eliminate it but it reduced it. They told me that if I had the prop barrel machined down a little that could help with the porpoising.
Did you have any work done on the bottom of your boat?
Hook removed etc?
Active Mike is offline
Old 05-22-2005 | 07:54 PM
I have not had any work done on the bottom, However i did enquire about removing the hook and was told removing the hook may make the poripesing worse. Did you try a noze cone on your lower? Do you think that would help?
ghaskell is offline
Sydwayz
Active Thunder
122
12-01-2011 12:24 PM
awsomethunder
Prop Talk
7
08-01-2006 06:51 PM
ghaskell
Active Thunder
16
05-22-2005 05:56 PM
ghaskell
05-18-2005 10:18 PM
WARPAINT
09-07-2002 12:59 AM
