-   -   731-741 or 502/502 cam? (https://www.offshoreonly.com/forums/general-q/103790-731-741-502-502-cam.html)
Scott 05-23-2005 09:11 AM
Re: 731-741 or 502/502 cam?
I decided to keep my Merc ignition with the Rev limit "set" at 5350rpm decided to use the 731 instead of the 741 for the above reasons. I am very happy with it and my overaul performance.
I have turn key engines that have a great idle and no loading or reversion.
Elite Marine 05-23-2005 07:49 PM
I'd like to see 5400+ for short bursts. My cam now is a real dog. i can't get much over 5000 RPM.
Whats the profile of the 731 vs 741?
jdnca1 05-23-2005 08:39 PM
go to www.cranecams.com
specs:
731 is 226/234 .587/.610" lift
741 is 234/242 .610/.632" lift
I'd suggest shooting for 5800 and running the 741 cam. Don't be afraid to turn some rpm! :p
For reference, a stock 500EFI cam is 230/236 .598/.610".
mikes280 05-23-2005 09:06 PM
Originally Posted by Pantera28-650HP
How would either of these cams work in a blower application. Lower boost 5 - 7 PSI?
Where are the spec cards for these cams?
I am in the search for a new cam for my motor also.
Not trying to steal your thread Migara422!!
yes i just did a 510 with the a fare set of heads and it made 903 hp at 8 lbs yes the 741 loves a blower
WETTE VETTE 05-23-2005 09:23 PM
Are the 741 and 731 cams ground on the same LSA for blown and NA motors? For some reason I thought I saw they are available on 112 for NA and 114 for blower apps. Just curious and thought it may be good for these guys to know when shopping.
Craig
migara422 05-23-2005 09:38 PM
If i dont plan on turning more than 5500 rpms, would the 741 be too much cam compared to the 731?
Strip Poker 388 05-24-2005 08:37 AM
I have all the take out valve train out of my 500efi. The 500 efi cam is real close to the 731 cam.I even have the valves and Crane rockers :D
I put the 741 in my blower motor.It worked good with the blower.
If you are going to buy new ? Call [Bob] RMbuilder and have him design one for your aplication it will be real close to the same price . He just did one for a member on this board and it picked up 9 MPH!!!
Elite Marine 05-24-2005 05:55 PM
I have the Federal Mogul Lifters. I'll have to look them up as far as limits for lift.
Dave F 05-24-2005 05:59 PM
I agree. the 741 for the blower is better. 731 for n/a. And to get all the torque, oval ports.
With the blower, rectangle ports and the 741. I have one in perfect condition if interested.
DAVE
migara422 05-25-2005 01:25 PM
Anyone know how to get in touch with RMbuilder?
Maybe he can help me with a cam
