105octane AV gas >
105octane AV gas
105octane AV gas
Old 05-24-2005 | 09:51 PM
Default Re: 105octane AV gas
you said (Octane rating is in no way correlated with engine power or efficiency) and is wrong!
fountain333 is offline
Old 05-24-2005 | 09:53 PM
I was refering to doing this once. No reason to just run the 105 out by itself. Use it to your advantage and mix it with some lower cost fuel.
Griff is offline
Old 05-24-2005 | 11:00 PM
Griff has the right idea. Burn down a little and the top with 93 octane fuel. AV gas runs great. I had a leaking fuel sender unit in one of the tanks of the plane this year. To change the fuel sender I had to drain the tank. Everything ended up with av gas. The generator, pressure washer, all the gas cans and lastly the truck. The stuff has lots of lead in it and it can hurt a cat converter. Anyhow the truck has never run better. The stuff will also last forever. It will not go bad quickly like car gas. It is truely a fuel of choice.
FlyFast is offline
Old 05-24-2005 | 11:06 PM
Outdrive1's Avatar
Masher touches my
I run av fuel all the time in my boat, fuel injected blower motor shuts down from knock sensor on 91 octane. Where do you find 93 octane? All they sell in Az. is 87, 89, or 91. I've thought about mixing 91 and av fuel but the price is about 3.05 a gallon for av fuel and 2.70 for 91, not worth my time driving it around to save 10 dollars when I fill it up it once every two or three times to the lake. I was thinking of trying some of that octane boost stuff because I had bought a bunch of it once in case I couldn't get some high octane stuff anywhere but have been too chicken to trust it. Does that stuff really work? Anybody ever use it?
Outdrive1 is offline
Old 05-25-2005 | 07:50 AM
Stormrider's Avatar
JC Performance Engines
I've heard the octane boost does not work.
I think I'll just burn off some more AV and then fill up.
I'm trying to find what prop works w/ the new engine and the AV gas isn't allowing the engine to give me true figures.
Any guess how many MPH I could be losing from AV gas?
On dyno... 560hp @ 5800 / 550lb/ft @ 4800.
Was running 75 @ 5500 w/ more to go.
Stormrider is offline
Old 05-25-2005 | 08:46 AM
Crazyhorse's Avatar
Originally Posted by checkmate454mag
While I have never treid AV fuels, I have heard that it doesn't run to burn well at sealevel. It is designed to be burned at altitude where the air is thinner. In any case, just make sure your fuel mixture is good when you switch to 93.
Not true. Aircraft have mixture controls for adjusting fuel mixture at altitude.
Crazyhorse is offline
Old 05-25-2005 | 08:58 AM
[QUOTE=FlyFast] Everything ended up with av gas. The generator, pressure washer, all the gas cans and lastly the truck. [QUOTE]
Next time I need fuel for my turbocharged leaf blower, I'll call you.
Gary Anderson is offline
Old 05-25-2005 | 09:33 AM
Brad Zastrow's Avatar
I stand by my statement. In easier english high octane gas does not make horsepower (engine power and efficiency), it allows you to use more compression to make more horsepower.
Here is website that explains octane very well.
http://www.prime-mover.org/Engines/G...es/octane.html
Brad Zastrow is offline
Old 05-25-2005 | 05:56 PM
Vinny P's Avatar
I hate the winter!!
I didn't know that. As I said, I had no personal experience with AV gas.
Vinny P is offline
Old 05-25-2005 | 07:06 PM
yes i understand that if you do not need the higher octane fuel then it hurts power it does not make more power ?? sheesh??
