-   -   Particles in Bravo 1 Drive Oil ? (https://www.offshoreonly.com/forums/general-q/104243-particles-bravo-1-drive-oil.html)
25 hors la loi 07-14-2008 11:44 AM
3 Attachment(s)
Ok some picture to share ....the verdict ?
25 hors la loi 07-14-2008 11:57 AM
3 Attachment(s)
Three more
Strip Poker 388 07-14-2008 12:39 PM
1 Attachment(s)
Pretty chunky,Ive been there:( Prob the lower gear [sp]breneiling,I would say it needs to come apart.
Mr Gadgets 07-14-2008 12:43 PM
Looks like gear material to me. I would pull the propshaft and inspect the gears. I would venture to say you will see missing metal on some of the teeth, along a line in the center of the face of the tooth, and on one or more of them. Before you remove the propshaft, rotate it in both directions to see what it feels like, then look. I'll bet the gears are worn out. Thank you very much Mercury Marine.
How much power? Prop size? Weight of boat?
Dick
25 hors la loi 07-14-2008 12:46 PM
Dick
Thanks guy , a 288 Sunsation 5000 lbs, 525 EFI , and B1 30 lab , just before summer vacation :hitfan:
thanks again
25 hors la loi 07-14-2008 12:56 PM
Dick
I need special tool to remove the prop shaft ? ,
zt260 07-14-2008 01:41 PM
Yes you do, and just that tool is about $150+, but unless you’re planning on fixing it yourself bring it to someone who has the tools and know how. Vinny P showed me how to do it this spring and I bought the tools. You will be out a grand or more in tools, so if you’re not planning on doing this regularly hire a pro. Dick is the master.:ernaehrung004:
Canada Jeff 07-14-2008 02:15 PM
20 hours ! Warranty ?? What year is yours? I thought you just bought it this spring?
25 hors la loi 07-14-2008 03:00 PM
Hello Jeff , sorry for my bad english , it`s 20 hrs after i put a new upper on my old lower (`06) , sorry for the confusion
Regards
Christian
Strip Poker 388 07-14-2008 03:33 PM
3 Attachment(s)
to take it apart you can do it yourself,the retainer ring has tabs bent over, straighten them and take a hammer and punch and spin off the retainer nut ,like a regular nut ,nut and tab washer will come out, the bearing carrier will come out,you might have to put 2 bolts in the bolt holes,twist/turn etc and it should come out, there glued in usually with perfect seal, gooey crap,shaft will come out then ya can see the gears.take anode off also,hope this helps:D
Then ya can send it to Mr Gadgets:D
