Tach jumps at hi RPMS.  HELP! >
Old 05-31-2005 | 11:27 AM
BillR's Avatar
OSO Moderator
Default Tach jumps at hi RPMS. HELP!
My starboard Motor Tach Wants To Jump 400-800rpms While The Motor Is At 4k or above.
Have Ruled Out The Tach Due To swaping tachs.
Had The Scan Tool Hook Up Which Show The Rpms To Hold seady at 4k or whatever RPM it was turning.
New Cap/Rotor.
What can cause this????
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-31-2005 | 11:37 AM
FOUNTAINATLAST's Avatar
Default Re: Tach jumps at hi RPMS. HELP!
I had a very similar problem that eventaully got to the point were it would jump around at any RPM. It ended up only being a bad electrical connention in one of the bulkhead connectors in the wiring harness. Trace down the wires from tach to motor check all plugs in connections and clean them out (WD-40 works good). Hopefully its as simple for you as it was for me, Good Luck...
FOUNTAINATLAST is offline
Old 05-31-2005 | 03:03 PM
baja36ft's Avatar
[QUOTE
=BillR]My starboard Motor Tach Wants To Jump 400-800rpms While The Motor Is At 4k or above.
New Cap/Rotor.
What can cause this????[/QUOTE]
BILL WHY DON'T YOU CHANGE COMPUTERS AND SEE IF IT HAPPENS.
baja36ft is offline
Old 05-31-2005 | 05:02 PM
MrCIG's Avatar
Charter Member#330
Just had one at from idle to 3000 rpm all was ok over 3000rpm the tach would jump to 7000rpm traced out all the grounds, switched tachs, changed modules, checked all connection on big plug.
Landed up being a bad coil. Funny thing is the motor ran fine.
Mark
MrCIG is offline
Old 06-01-2005 | 07:15 AM
BillR's Avatar
OSO Moderator
I have new ignition coil.
I'll try the grounding thing and swap computers.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
TeamSaris
General Racing Discussion
50
03-16-2006 05:56 AM
JROMY
08-20-2003 07:53 PM
