Fuel Pressure Gauge >
Fuel Pressure Gauge
Fuel Pressure Gauge
Old 06-01-2005 | 01:11 PM
DORaymond's Avatar
Default Fuel Pressure Gauge
I have twin Mercruiser 502 Magnum MPI's (2000) and my question is this: Does the MEFI 3 ECU measure and use fuel pressure? Can I use the signal to display the pressure on dash gauges? If not, where would I mount a sender to measure fuel pressure?
DORaymond is offline
Old 06-01-2005 | 02:56 PM
articfriends's Avatar
Default Re: Fuel Pressure Gauge
There is no transducer to tell computer actual fuel pressure. The best place that i know of would be to remove the brass pipe plug in rear of fuel rail (near distributer) and install a tight 90 dgeree fitting with a sending unit,Smitty
articfriends is offline
Old 06-01-2005 | 03:00 PM
Dave_N's Avatar
MEFI 3 systems do have the ability to connect to a fuel pressure sensor, but none were ever installed on the 502's, or anything else as far as I am aware.
I have installed Gaffrig fuel pressure gauges by extending the fitting at the front of the fuel rail, and "T"ing in the sender with the schrader valve. I have a picture somewhere, if you want I will find it and post.
Dave
Dave_N is offline
Steve_H
4
02-03-2007 11:58 PM
bcarpman
18
01-20-2007 05:55 PM
customryder
5
06-28-2006 08:21 PM
mats
2
05-05-2003 04:59 AM
jadento
1
05-20-2002 08:16 AM
