Capping Y pipe >
Capping Y pipe
Capping Y pipe
Old 06-03-2005 | 11:15 AM
RBake's Avatar
Default Capping Y pipe
I searched and couldn't find anything on this, so be easy if I missed something.
I'm installing thru hull on a 22 Hammer that doesn't have it at all now. What's the best way to cap the Y pipe without having to remove it from the boat. Is there a special cap for it??
Thanks,
Robert
RBake is offline
Old 06-03-2005 | 12:28 PM
tssteph's Avatar
Default Re: Capping Y pipe
Both (actually all four) are capped in mine. They were done when I got the boat. Caps came from a plumbing supply house and they are double clamped.
tssteph is offline
Old 06-03-2005 | 12:37 PM
I added thru hull to my Baja soon after I bought it. Thought I would add silent choice sometime but I never found the need so they have been capped for 10 years. I used 4" schdl 40 PVC I believe it was a female clean out with a threaded cap to close it. Just measure the OD of your horseshoe and be sure to double clamp it.
Also I recommend coating your newly cut holes in the transom with resin it will help keep moisture out.
baja208 is offline
Old 06-03-2005 | 12:38 PM
dyno's Avatar
Charter Member #655
yep got the caps for mine at Lowes.....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-03-2005 | 12:39 PM
DanB's Avatar
Charter Member #71
Go to home depot and get a couple of the expandable sewer pipe caps with wing nuts on the end. You need to leave the rubber connecting hose on the Y pipe. Looks a little funky but works great. Remember all you are puting them there for is in the event the water level outside is higher then the top of the Y pipe. Not likely.
DanB is offline
Old 06-03-2005 | 12:40 PM
tssteph's Avatar
Mine are actually a rubber cap, sounds like yours are PVC.
tssteph is offline
Old 06-03-2005 | 12:45 PM
DanB's Avatar
Charter Member #71
Yep........mine were some kind of plastic. I use them now to seal the ends of the exhuast tips when the boat is not in use. Keeps the geckos and critters out of the motor.
DanB is offline
Old 06-03-2005 | 12:47 PM
WHOSNEXT's Avatar
Sorry for the stupid question but why are you guys doing this for for a louder boat?
WHOSNEXT is offline
Old 06-03-2005 | 01:03 PM
Preformance Dude
Badtoon is offline
THRILLSEEKER
2
05-14-2008 04:40 PM
waterboy222
Detailing, Painting, & Fiberglass
3
06-13-2007 09:31 PM
evaluex
1
09-22-2006 09:18 PM
Cord
11
12-07-2003 09:33 AM
SLINGSHOT
08-28-2002 08:29 AM
