Hot water temp >
Hot water temp
Hot water temp
Old 06-08-2005 | 07:58 PM
hillbilly24's Avatar
Default Re: Hot water temp
An impeller had taken a set when the vanes no longer hold tension against the housing when the impeller is new the vanes are straight and over time they loose there ridgitity and allow water to bypass around them. Also take a good look at the housing, if it has grooves or the endplate is worn this will also cuase water to bypass.
hillbilly24 is offline
Mat Raymond
3
01-12-2009 01:13 AM
Pmpaint1
3
04-25-2005 11:10 AM
boat4life
4
05-06-2004 06:04 PM
HARRISONMIRAGE
12
04-18-2004 12:49 PM
Mrgoodwrench
3
03-25-2002 11:43 PM
