Replacing Guages >
Replacing Guages
Replacing Guages
Old 06-14-2005 | 11:32 AM
Default Replacing Guages
Thinking of replacing Gaffrig Monster Speedo with GPS. How do you remove the guages?
Showdown is offline
Old 06-14-2005 | 11:53 AM
Wally's Avatar
Were doomed!
Default Re: Replacing Guages
If you have a panel on your boat you will need to unscrew it and lift it up to get to the back of the gauges....there you will see a "U" bracket held down by two nuts undo those and the guage will be loose.....then just make sure to either mark/take pictures or remember where each wire goes back.
If no panel then you have to figure out how they installed the gauges....maybe from under the dash? Or maybe from behind in the cabin?
-Wally
Wally is offline
Old 06-14-2005 | 11:58 AM
Thanks Wally--It's an 04 25 Outlaw so I can remove the entire panel and get at it---how is the bezel attached
Showdown is offline
Old 06-14-2005 | 02:02 PM
Wally's Avatar
Were doomed!
it depends on what kind of bezel you have....if its one thats under the gauge then t just sits there sandwhiched between the gauges and the dash......if you have the colored trim ring on the gauges itself then you are SOL cause you cant take those off.....you'll know realy quick once the gauge is loose...
-Wally
Wally is offline
10M
Fountain
7
04-16-2008 11:34 AM
resurrected
3
05-10-2007 06:04 PM
FWK
02-04-2004 04:57 PM
SledgeHammer
Baja
0
07-08-2003 08:39 AM
puder
05-28-2002 01:12 PM
