Water temp for a 454mag efi >
Old 06-15-2005 | 10:54 PM
Default Water temp for a 454mag efi
What should my water temp be running on a 96 454mag efi? It seems to take forever to warm up and then reads about 125 until ?I get on it. Then runs about 150
HOTTZU98 is offline
Old 06-16-2005 | 12:07 AM
Poorsche's Avatar
Default Re: Water temp for a 454mag efi
Sounds your thermostat isn't present or it's not working. My efi 454's are fresh water cooled and specs say 160 degree stat--raw water stat is 140 degree.
Mine run aroune 150-160 at cruise (3200RPM) kick up to 170-180 at WOT.
Boat is a Formula SR357 with TRs drives and weighs over 10K. Engines are MarinePower 454 EFi using Arizona Speed TPI.
Poorsche is offline
Old 06-16-2005 | 04:35 PM
East Coast B's Avatar
I'll ditto that.... Sounds like thermostat is stuck open and allowing continuous water flow to the engine thus preventing it from warming up to where it should be... The thermostat is an easy swap out..... just yell if your not sure how to..... Good luck!
East Coast B is offline
Old 06-18-2005 | 09:38 AM
tHAT IS WHAT i THOUGHT IT WAS. i HAVE A COUPLE NEW ONES IN THE GARAGE. THANKS
HOTTZU98 is offline
Fast Forward
1
08-14-2005 09:46 AM
HOTTZU98
3
07-19-2005 03:30 PM
HOTTZU98
2
04-30-2005 06:29 AM
hotrodtodd32
11
02-15-2003 03:36 PM
Checkmate283
09-23-2002 05:03 PM
