petrolum oil vs, synthetic >
Old 06-18-2005 | 09:08 PM
Talking petrolum oil vs, synthetic
im buying a 700+ h.p. motor and the they told me to use only regular petrolum oil in it .and sythetic oil does not lubercate some of the engine parts as well .can any one tell me why .thank you
mikebrls is offline
Old 06-18-2005 | 11:08 PM
mwdill's Avatar
Default Re: petrolum oil vs, synthetic
use petro for break in, then use syn, don't know what they are talking about when they say" some engine parts"?
mwdill is offline
Old 06-18-2005 | 11:25 PM
articfriends's Avatar
That probably goes back to teague telling people that hyd roller cams get flat spots in the wheels from sliding over the ramps on cam. There are a few instances,usually in drag or circle track motors with super low, low ring tension where moly or some of the other super slippery addittives might cause problems with ring seal but i can't see it on a marine engine,Smitty
articfriends is offline
Old 06-19-2005 | 01:01 PM
I'm Not Shure What Parts They Where Talking About They Just Said Petrolum Oil Lubercates Better .
But From What I Read Every One Says Synthetic After Break In .
Thank's
mikebrls is offline
Old 06-19-2005 | 01:49 PM
Hydrocruiser's Avatar
Arrow Re: petrolum oil vs, synthetic
Thank's
Ask 'em what parts they are concerned with...and get back to us.
Hydrocruiser is offline
Old 06-19-2005 | 05:18 PM
In light of some reports I read today on Bob's site about 15W-50 Mobil-1 Goldcap shearing down rapidly and some engines dropping oil pressure as a result...my former strong conviction of using either Mobil-1 V-Twin or Redline 20W-50 is back in effect. If you use Goldcap it is still better than a conventional oil but change it as if it were a conventional oil.
Bob's guys wish Redcap was still available because the Goldcap is not looking all that great from a HTTP standpoint with UAO's that keep coming in.. It is probably a sign that the additive to basestock ratio is not nearly as good as Redcap was.
Sammy
9
08-18-2009 04:05 PM
BAD-HABIT
9
10-28-2005 07:58 PM
mleslie951
27
11-08-2004 08:03 PM
