oil pressure problems from stock hardware >
Old 08-26-2009 | 04:12 PM
  #111
Mine sees 20PSI at around 800rpm on the mech gauge I have running of the filter pad but that's when the motor is cold.
My elec sender in the block doesn't seem to like to read down that low so I've ordered a new one.
Ghostrider is offline
Old 08-27-2009 | 08:00 AM
  #112
PatriYacht's Avatar
Whippledmach, do you know what your air/fuel ratio's are? Make sure you are safe or your engine will melt. At that hp level you should use an oil cooler with a 3 x 18 inch element.
PatriYacht is offline
Old 11-25-2009 | 10:34 PM
  #113
Originally Posted by Sport 280
I have read this thread two times, great information. I have Gen VI Lingenfelters with the side oil pad bypass blocked. These Gen VI blocks have a bypass in the center return on the oil pad. Sounds like from the discussion, this bypass should be removed. If so, how do I remove this center return bypass.
Fred
A long 2 or 3 inch 3/8 bolt will thread right in to it and them just pull it and wiggle it out
Rockfish71 is offline
Old 11-26-2009 | 12:58 AM
  #114
Removed and blocked with I think a 20mm welsh plug from memory. Don't just remove it (obviously).
Sorry if that was suck eggs, you can never be too careful!
Old 11-26-2009 | 09:49 AM
  #115
the center one does not need to be blocked
outlaw is offline
Old 11-26-2009 | 10:01 AM
  #116
This is what I have done on my gen 6 block
I removed the outer bypass and installed a 20mm plug
and staked it in 4 places as shown in an earlier pic
I also removed the inner bypass located under the threaded adapter and left it out( the passage under the center bypass leads to the 3/8 fittings on the pan rail, mine are plugged, so leaving the center bypass out has no effect)
I'm going to use a REX marine adapter 456-412 that attaches
with the two 5/16 threaded holes on the filter pad, this requires the removal of the threaded center adapter
outlaw is offline
Old 11-26-2009 | 12:09 PM
  #117
I have the side bypass blocked with plug 20 mm plug. I want to remove the center bypass located under the threaded adaptor, how do I remove the center bypass?
Fred
Fred I used a slide hammer, You can use anything with a hook
on it and just pull it out.
outlaw is offline
Old 11-26-2009 | 01:51 PM
  #118
My bad, I miss read the part where he said middle one!!
Hey, at least I go the plug size right!
Old 11-26-2009 | 04:45 PM
  #119
outlaw is offline
Old 12-27-2009 | 06:34 PM
  #120
hondatv's Avatar
Originally Posted by outlaw
Thanks outlaw for showing me this great thread
I'm pluging mine
hondatv is offline
