oil pressure problems from stock hardware
#191
Thanks I'll have to check into the location of the block adapter. I'm guessing this is where the oil filter would be in an automotive application, bottom side?
I have low oil pressure on a OE 416 hr. '96 7.4 lx mpi. Aside from a bad dash mount oil pressure gauge I don't see why the pressure would be low. I'm hoping switching the valve would help with the pressure issue.
AllDodge (04-26-2021)
#192
A 11 lb autiomotive valve can only open and allow unfiltered, uncooled oil to bypass the cooler and filter resulting in engine damage if its original with standard volume oil pump, unless bypass is hung open, i doubt its your problem though. Im of the understanding mercruiser used the stiffer bypass valves but not 100% sure. The lines, cooler and bypass were sized appropriately from factory for stock clearances and standard oil pump and usually work for hundreds of hours. Now, if someone put a high volume oil pump in, then it could be bypassing the cooler and filter, smitty
