Supercharger >
Supercharger
Supercharger
Old 06-29-2005 | 11:24 AM
Default Supercharger OIL,WHAT TYPE?VISCOSITY?
What Type Of Oil DO THE Superchargers On My 525sc USE?
JJONES is offline
Old 06-29-2005 | 12:07 PM
Default Re: Supercharger
I ran Mobil 1 15-50 in my procharged 502s. But check out this thread
http://www.offshoreonly.com/forums/s...ad.php?t=83930
I just bought some of the Mobil 1 20-50 V twin for my 540 N/A.
Pure Energy is offline
Old 06-29-2005 | 02:17 PM
What Viscosity Is Used In Super Chargers?
JJONES is offline
Old 06-29-2005 | 02:22 PM
i beleve it 90 wt.
customryder is offline
Old 06-29-2005 | 02:30 PM
I run the Merc Hi-Perf gear lube in my 525SC blower. The same stuff that goes in the drive. Change it every 30-50hrs.
You have to suck it out with a small vacuum hose or similar. I have a large syringe with a tube on the end and that gets it out pretty well. It does not hold very much, maybe 3-4oz on each side. The lube in the front and back of the case is totally separate and both need to be changed. The front has a dipstick. The rear has a fill hole.
Griff is offline
Old 06-29-2005 | 02:48 PM
JJONES is offline
Old 06-29-2005 | 04:23 PM
Steve Zuckerman's Avatar
I'm using Royal Purple 75W90 Max-Gear in my Weiand/Merc 256 on my 575 with good luck. I think the Merc oil is OK too. The biggest thing to remember is to check it regulary and change it every 50 hours. An easy way to remember it is just change it every time you change outdrive oil.
The gear oil in the supercharger can get diluted with gasoline, which is hard on seals, bearings and shafts.
Regards,
Steve
Steve Zuckerman is offline
Old 06-29-2005 | 05:30 PM
ooops, sorry, misread your question
Old 06-29-2005 | 06:32 PM
Thanks For The Help,no Problem On The Miss Read,that Info Will Help Later
JJONES is offline
bichaum
31
02-08-2008 05:26 PM
mtocrs1
7
02-20-2007 09:06 PM
Bryan Rose
5
11-14-2006 03:28 PM
Wally
07-16-2002 10:59 AM
rocksolid
5
02-26-2002 05:08 PM
