-   -   Bravo alignment with Offshore mounts? (https://www.offshoreonly.com/forums/general-q/106726-bravo-alignment-offshore-mounts.html)
dyno 06-30-2005 12:22 PM
Re: Bravo alignment with Offshore mounts?
same couplers, same u joints,same mounts, Tinkerboater is going to bring his alignment tool over tonight that way I know where to start.
Gary Anderson 06-30-2005 12:28 PM
Did you put the mounts on the same side they were before. The L angles are drilled to align the front of the engine. Subtle changes can have big effects.
Use an alignment tool. See what needs to be changed.
You can make a 3 hole or slotted shim to put between the mount and engine if it's minor.
If major changes are needed, redrill the L angles.
Gary
Mbam 06-30-2005 04:21 PM
New flywheel housings? The latest version does not use spring washer.
Scott 07-01-2005 09:10 AM
I see you got it fixed although I can't imagine Foul being any help :D
Can you let us know what you had to do to take care of the problem? :cool:
Zanie 07-01-2005 10:06 AM
Yes please post the problem so others (me) can avoid it!
dyno 07-01-2005 10:24 AM
Mike was great moron support! we got it handled last night, took everything lose and used and alignment tool, all set ! Thank God!!!
Wobble 07-01-2005 11:39 AM
Come on Dyno, your not telling us what you found!! We need to learn from your experience.
"Chasing knowledge" one post at a time :evilb:
tomas_wallin 07-02-2005 04:53 AM
Yes, come on now and let us know! :evilb: Everyone needs moron support sometimes (except for me... :p ).
FOUNTAINATLAST 07-02-2005 08:03 PM
Maybe he's to embarrsesd to tell us what he forgot to do??? :D :D :D
Common fess-up, we promise we won't laugh!!! :rolleyes: :eek: :evilb:
dyno 07-05-2005 05:34 AM
I just took all the bolts lose replaced two of them with a tapered pin jumped up and down on them a couple times and bingo! engine aligned.That was the port motor the starboard just needed the gimbal bearing straightened out with the alingment tool.
