502 backfires >
502 backfires
502 backfires
Old 06-30-2005 | 10:41 PM
Default 502 backfires
checked compression 150 all 8 fuel pressure 34 psi timming ok engine is a 1995 mpi plugs cap and rotor new back fires worst at 2000 rpm help?
charity is offline
Old 06-30-2005 | 10:48 PM
FOUNTAINATLAST's Avatar
Default Re: 502 backfires
Was this a previous problem or start after plugs, cap, & wires??? Firing order correct???
FOUNTAINATLAST is offline
Old 06-30-2005 | 11:03 PM
firing order is correct engine has set for 8 months ran fine before
charity is offline
Old 06-30-2005 | 11:31 PM
offthefront's Avatar
Run a can of merc fuel treatment and also a quart of MMO in the crankcase .....
offthefront is offline
Old 06-30-2005 | 11:39 PM
whats mmo? i PULLed injecters to have cleaned and flow tesed will install in the morning
charity is offline
Old 07-01-2005 | 08:15 AM
KNOT-RIGHT's Avatar
Is the backfire coming from intake or exhaust?
KNOT-RIGHT is offline
Old 07-01-2005 | 08:19 AM
exhuast does drive oil moniter not hooked up cause fuel cut ?
charity is offline
Old 07-01-2005 | 08:43 AM
thespy's Avatar
mmo=marvel mistory oil, red and black quart can.
thespy is offline
Old 07-01-2005 | 08:47 AM
KNOT-RIGHT's Avatar
Is backfire coming from both exhaust banks?
Old 07-01-2005 | 09:36 AM
both banks
charity is offline
