525 oil Temp Range
Wondering what the Oil temp ranges were reading on the new 525's. Mine range between 190 to 240 @ operating temp.
Re: 525 oil Temp Range
mine will stay about 180 to 190 than when I make a long run and than idle for awhile it will go to 220.
every person on here has a opinion. I don't think you can go wrong with a synthetic oil. Some may be better than others but I have used valvoline conventional my whole life and have not had any problems. I now use mobile one synthetic.
mobile one came stock in my new corvette. I think gm kows about oil. ( for warrany reasons).
mobile one came stock in my new corvette. I think gm kows about oil. ( for warranty reasons).
Bob's guys are stashing old formulation oil...it is much better than the new stuff... Now some companies have non-API rated oils...they don't conform but are still out there...like Amsoil Series 3000 5W-30 or Mobil-1 MX2T 10W-40 Motorcycle oil...or our friend 20-50 Mobil-1 V-twin...most of Bob's guys who don't have a stash are mixing oils...adding a quart or 2 of 15W-50 to 3 quarts of 10W-30 as the newer stuff is not holding up as good..the new conventional oils are pitiful with low ZDDP.... Goldcap recent samples showed higher ZDDP but the base is lower...it's crazy...Mobil is reformulating many synthetic and non-synthetic products as are other compnaies as well. You can imagine how pi**ed off I am after getting this thing all figured out. :( Choose carefully... |
and you can imagine how confused I am...
The big blower guy's mechanics are amazed at how well Mobil-1 V-Twin protects when doing teardown inspections.. It may be the best marine synthetic ever made..though it has a "picture of a motorcycle" on the label... :D |
