Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 01-09-2007 | 11:50 AM
  #1101
sleeper_dave's Avatar
Default Re: Marine Lubrication
Originally Posted by sleeper_dave
I'm going to put an oil thermostat on my boat, because the oil wasn't getting past 140°F for most of last summer.
Should I get a 180°F thermostat, or a 200°F thermostat?
http://www.racerpartswholesale.com/mocal.htm
Anyone?
sleeper_dave is offline
Old 01-09-2007 | 11:57 AM
  #1102
You want the oil temp above 212 so the water burns off. KEPP sells one that is between 215 and 220.
BenPerfected is offline
Old 01-09-2007 | 12:20 PM
  #1103
you mean this one?
http://www.keitheickert.com/detail~ID~1035.aspx
For twice the price? Yeah right.
So, back to my original question, is a 180° stat okay, or should I spring the extra $25 for a 200°F stat?
Personally i'm leaning toward the 180° stat. I'm sure the oil will see a higher temp somewhere in the engine that would allow it to burn off water. But that's not my primary concern, as I had zero water contamination after 25 hours without the oil seeing more than 160°F, usually below 140°F.
Old 01-09-2007 | 12:48 PM
  #1104
Your oils temp should be a min of 180. Water will "burn off" at this temp but it will just take a little longer. My small block has a 140 thermostat in it, I do not know what my big block thermostat is.
Ken
minxguy is offline
Old 01-09-2007 | 04:50 PM
  #1105
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
you mean this one?
After I pound a pair of 502's for an hour and take a read of my oil filter with my heat seeking ray gun it shows as much as 230*F and that's with a 200*F stat.
A good hard run makes this debate loose wind?
Hydrocruiser is offline
Old 01-09-2007 | 07:17 PM
  #1106
A constant oil temp assumes that you have an oil cooler with enough capacity to keep the oil temp at or below the thermostat rating at all loads for an extended peroid.
Old 01-09-2007 | 09:05 PM
  #1107
With gas being 3.50 a gallon last summer i didn't run that hard very often. I have a 16" oil cooler, and most of the time the gauge didn't budge off 140. I do a lot of boating in the early and late season with water temps as low as 40°F.
Old 01-10-2007 | 08:27 AM
  #1108
I missed some posts ,what does PAO stand for ??Catch me up to date.
MYSKATER32 is offline
Old 01-10-2007 | 10:02 AM
  #1109
Polyalphaolefin, it is a true synthetic base stocj.
Ken
minxguy is offline
Old 01-10-2007 | 05:26 PM
  #1110
FYI...the latest reformulation of M-1 Extended products has Group IV back in them. It may be a III/IV blend.
15W-50 M-1 is back on my "A" list.
See ya
