Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 02-28-2007 | 06:11 AM
  #1181
Originally Posted by Hydrocruiser
Wix Racing Oil Filter or K&N.
I hope they fit.
Pismo10 is offline
Old 02-28-2007 | 09:01 AM
  #1182
K & N Filters:
HP-2002 is 4.60" in Height &
HP-3002 is 5.52" in Height.
Both have anti-drain back valves and a can burst strength of 362.3 PSI which is almost double that of the Fram.
phebus is offline
Old 02-28-2007 | 07:26 PM
  #1183
Hydrocruiser's Avatar
Arrow
Originally Posted by phebus
K & N Filters:
We just hear so much good stuff about K&N from the drag racers that one has to believe they are a great choice for offshore.
Unless you run over 1000 HP and need the Orange Fram Tin Cans..these are great.
Wix racing and Baldwin puts a lot into the case and core as well.
Mobil-1 and Amsoil are decent for 502's and 525's in non-racing applications as both are new and imrpoved for better efficiency and flow.
Hydrocruiser is offline
Old 03-01-2007 | 07:43 AM
  #1184
sleeper_dave's Avatar
I just bought 12 quarts of m1 v-twin from www.cyclegear.com for $7.99 a quart. Everyplace else seemed to want $9-$10 a quart. I paid $10 to ship 12 quarts. Hopefully it'll get here with no problem.
I'm just running a stock carb'd 502. i plan on using v-twin with a m1-302 filter, and i'm going to try to get a whole season (50-80 hours) out of the oil with filter changes and an analysis every 20 hours or so.
sleeper_dave is offline
Old 03-01-2007 | 10:45 AM
  #1185
Mentalpause's Avatar
I buy it at the local auto parts store at LOTO for 7.79, but I buy more volume to get that price. Last month I picked up 8 cases.
Mentalpause is offline
Old 03-01-2007 | 11:39 AM
  #1186
Arrow
In a solid condition 502 expect you can safely go out to 60 hours on V-Twin. If you change the oil filter at 40 hours then getting to 80 hours is a reasonable expectation. A Group IV/V can go twice the manufacturer's recommendation with a filter change inbetween unless you are racing.
Fuel or water getting into the oil or running WOT extensively can change that scenerio.
Best thing to do is when chacking the oil smell and look at it closely.
Old 03-01-2007 | 02:50 PM
  #1187
My big problem last year, according to the analysis, was fuel getting into the oil. I suspect the engine is running rich at idle, and plan to do a tune up in the spring. Also, the oil was running very cold last year, i will be adding an oil thermostat to bring up the temperature this year (since i usually start my boating season when the water temp is still in the 30's).
My plan is to change the filter and top off at 20 hours, and get an analysis. I will likely repeat that every 20 hours all season, unless the 20 hour analysis comes out exceptionally clean, then i may stretch the interval to 40 hours.
I looked around and never found v-twin at any local auto parts stores or at wal-mart. I'm in the Detroit area, maybe it just doesn't sell well enough here.
Old 03-01-2007 | 07:51 PM
  #1188
Arrow
Mike at Sterling had told me a while back that if you smell gas on the dipstick change it.
Old 03-05-2007 | 09:51 AM
  #1189
K & N Filters:
The K&N 2002 just wont fit, close but not there. So Ill try the Wix 51069R which is a little shorter. Will post success or not. Non-racing Wix 57099 will fit but how good are they? Will try the new M1-111 as well.
Thanks for the help. I need to remount and use the larger filters.
Pismo10 is offline
Old 03-05-2007 | 03:08 PM
  #1190
Yes i've heard that many times, but that doesn't help.
I need to address why gas is getting in the oil to begin with. This is an NA motor, a stock 502 with under 150 hours since a rebuild. Hopefully some adjustments to the carb and new plugs and wires will eliminate the fuel in the oil to begin with.
If not, i'm going back to super cheapo oil because i'll be stuck changing it twice a month anyway.
