Marine Lubrication
#1461
What specific Amsoil and Redline oil did you try in your application and found to be great?
Just a brief comment...
I pick an oil...one that appears to be good....run it for say 15-20 hrs...do an oil analysis...if it is good in my application I know... if not try a new product.
I have found in testing Mobil-1/Amsoil/Redline and RP.. that they all were great. Never found one to be "bad"...
The biggest mistakes I feel in choosing a synthetic or any oil... is getting the wrong viscosity for the wrong engine/climate; especially if it is cold out and the oil is too thick.
#1462
What would be the coldest ambient temperature that one could still run a 20W50 like Amsoil Series 2000 race oil in a marine engine (Merc 496) with closed cooling and 120F thermostat that runs ~135F coolant temperature when warmed? The bearing cllearances are now ~0.0025" and ~0.003" mains with HV oil pump. 30F?
#1463
Hydrocruiser,
I combined your data with mine.
The Silver Cap is only a few % points less Zn and P than the first line oils listed. I guess the big difference is its base stock is not 100% syn so viscosity stabilitry and byproducts of petrolium base oil breakdown with use is the shortfall?
Thoughts?
Thoughts?
#1464
#1465
The water would freeze and 20w50 oil will pour.
The important temp is running temp of the oil and it should be over 180F.
To qualify as a 20w oil you must meet a spec in the cold cranking simulator of 9500cP (centipoise) at -15C ASTM D 5293.
If you use a 20w50 in cooler temps, just make sure it is good and warm before you start applying lots of throttle.
Actually, no matter what oil you use you should make sure it good and warm before you run hard.
Ken
Ken
#1466
Thanks.
I am adding an oil temperature thermostat (195F) and gage so that will not be a problem. I just was not sure if the initial flow through the bearing clearances during cold starts/idle would be abequate so as to not be a problem before oil is warmed. I have always idled until the engine coolant temperature is stabilized warm.
Ken
Ken
#1467
Hydrocruiser,
Thoughts?
Thoughts?
Additive wise Motul uses Mg mostly and Amsoil Ca..which is fine.
The Motul is a double ester base and they sstill say V-Twin in a Grp iv/v. The high the basestock the more resistance to shear.
The M-1 SilverCap is a great value as it is right up there and priced nicely.
#1468
Thanks.
#1469
